Old November 2nd, 2018, 01:56
NepaXJ NepaXJ is offline
Engine won't crank. Not the battery. New starter
For a while i could put it in gear then back to park and it would crank but now it doesn't even work. I also lost power a couple of times while driving and had to pull off and restart the engine. It's been been having a hard start for a while. Any ideas?
Old November 2nd, 2018, 03:46
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Engine won't crank. Not the battery. New starter
You should start with some basic preventative maintenance and troubleshooting, right ? Are all the tune-up parts fresh ?
Random stalling should make one suspect a faulty Crankshaft Position Sensor (CPS). The CPS should be tested.
As a test, bypass the Neutral Safety Switch (NSS).
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Copper wires should be copper color, not black or green. Do the same for the grounding wires from the starter to engine block, the ground wires at the coil, and the ground wires from the battery and engine to the Jeep's frame/body. You must remove, wire brush, and clean until shiny the cable/wire ends and whatever they bolt to.
Test the output at the alternator with your Volts/Ohms Multi-Meter . You should be measuring 13.8-14.4 volts. Load testing the alternator is still recommended.
Place your Volts/Ohms Multi-Meter on the 20 volt scale. First check battery voltage by placing your multi-meter's positive lead on the battery's positive post ( the actual post, not the clamp ) and the negative lead on the negative post. You need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your positive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then you have excessive voltage drop in the starter circuit.
Typical voltage drop maximums:
• starter circuit (including starter solenoid) = 0.60 volt
• battery post to battery terminal end = zero volts
• battery main cable (measured end to end) 0.20 volt
• starter solenoid = 0.20 volt
• battery negative post to alternator metal frame = 0.20 volt
• negative main cable to engine block = 0.20 volt
• negative battery post to starter metal frame = 0.30
• battery positive post to alternator b+stud = 0.5 volt with maximum charging load applied (all accessories turned on)
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old November 3rd, 2018, 20:49
lawsoncl lawsoncl is offline
If it cranks when you put it in neutral, the neutral safeyy sensor probably needs cleaned up. Do a search, there are plenty of writeups for it.
Old November 5th, 2018, 13:34
Jim Malcolm Jim Malcolm is offline
This issue is not related to the NSS. Not saying the NSS isn't part of your problem, but you have another problem as well. I suspect the ignition switch or related wiring.
Old November 6th, 2018, 04:02
8Mud's Avatar
8Mud 8Mud is offline
What year? There is a TSB for the mid nineties models to tighten the screw at the end of the PDC (bus). A wire goes from the positive battery terminal to the PDC, the screw to tighten is under a small cover on the battery end of the PDC.
Old November 6th, 2018, 14:38
Waynerd Waynerd is offline
Not sure about the XJ but my old ZJ one time wouldn’t crank and it was the fuel pump. Apparently when there was no fuel it would kill the asd relay.
Old November 7th, 2018, 05:37
br1anstorm br1anstorm is offline
I had a similar problem on my 93 XJ.
I have always had a slightly dodgy NSS. Sometimes it wouldn't start when in Park. Shifting to Neutral usually enabled it to start normally.
When I suffered more frequent no-start issues, I thought it was a faulty Crankshaft Position Sensor (CPS), so I replaced it. No improvement.
The problem turned out to be a faulty - or failed - ignition coil. That does produce symptoms such as those you describe (occasional loss of power, and hard-starting). So check the coil for decent spark. It's also easy and cheap to replace it.
Old November 8th, 2018, 07:38
Saudade's Avatar
Saudade Saudade is offline
A few more details are needed too.
What exactly happens when you crank? Nothing? Do you hear a "click" or "clank"?
On the end of your starter are 3 terminal posts. Two large, one small. One large is you battery +. The other large feeds power to the starter motor. The small get 12v from your starter circuit to energize the solenoid.
If you crawl under where your starter is located, you can see them all. I attach a jumper wire (mine is 4 ft with alligator clips) to the small post that then run up the bay to touch to my + battery post , key off, in park, ebrake on, wheels chocked. Starter should crank (engine will NOT start). This bypasses every other junction, switch, relay etc. This can confirm or deny the issue is your starter, your battery, or battery connections. You can them work your way upstream.
NSS is my guess based on your post. There are tons of post and YT vids on how to bypass the NSS.
Good luck.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
WTB Starter and a Battery thanasi85 Sierra Chapter For Sale 3 May 2nd, 2013 08:31
Slow Crank and Starter Question 98NWCherokee OEM Tech Discussion 8 September 13th, 2012 19:44
No Crank - No start - Starter Resolution Zel94XJ OEM Tech Discussion 6 July 10th, 2010 09:06
starter solenoid engages, but no crank ehall OEM Tech Discussion 13 May 26th, 2008 10:42
Battery or Starter? karstic OEM Tech Discussion 5 February 5th, 2004 17:34
