WTB: Factory Extended Idle switch bezel for pre 97 XJ
90Pioneer
USA
I am looking for a factory extended idle switch bezel that'll fit right into my 1996 Jeep Cherokee. They came on XJs with the Police Package. I believe anything from '87 to '96 will work.
I will pay a good price. I also have a couple fog light switch bezels if you are interested in trading.
[email protected]
Thanks
I don't want the original switch but I thought I had seen some instuctions on how to do this yourself somewhere, does anyone have a link? How high does it idle with this setup?
I was thinking for OBA and during winching operations.
You can install a hand throttle to do the same thing. Or if you are good with servos and such it can be done electronically.
I tried to find the bezel a few months ago and didn't have any luck. The factory part has been discontinued and I couldn't find any used bezels either. I just took a razor blade and cut out the plastic cover from the hole in the original blank bezel and put the new switch in the hole. The switch ground a wire that hooks directly to the engine controller through the P/S pressure switch input pin. It raises the idle to around 1100rpm when in park or neutral when the pin is grounded.
Bryan
