Blower Motor
techno1154
In the islands
The one in my XJ is making a weird and horrible noise as of yesterday. I need to get a replacement. From where do you get replacements? I am not sure which years will interchange with the 1996 year model if I decide to go with one from the Pick and Pull. Or maybe a new budget priced unit will be the way to go,....
I got one from RockAuto a couple years ago. Only issue I had was having to use a grommet and a length of hose because the "vent hole" on the housing was clocked differently to the original one in my '92, but otherwise it bolted right up and plugged in fine.
I second RockAuto.
Thanks everyone. I have one on the way.
Next question,...
How do one seal between the blower housing and the body panels? I want to avoid dismantling the interior of the XJ to replace that dried up foam seal.
