waggy 44
Ironmen77
#1545
Nowata,Ok.
Does a '84 wagoneer have 44's front and rear? Got a line on a 1983 that runs with a 1984 for parts $650.00 for both.
the rear could be a model 20, the diff cover will have the bolts in a perfect circle. it's almost as strong as a D44 but has less aftermarket.
the front will be a driver's side drop D44, but it could have the funky vacuum disconnect (very obvious on the diff cover) that makes it less desirable.
the front will be a driver's side drop D44, but it could have the funky vacuum disconnect (very obvious on the diff cover) that makes it less desirable.[/QUOTE
Thanks, thats what I needed to know.
