Old March 1st, 2005, 08:19
redyouch redyouch is offline
Will 97+ interior door panels fit a 84-96
just wondering if 97+ door panels will fit on a 84-96? i know that the power window switches would probably have to be spliced. but would the lock mechanism line up and work? thanks
Old March 1st, 2005, 11:02
Re: Will 97+ interior door panels fit a 84-96
bttt
Old March 1st, 2005, 12:13
Dingo509's Avatar
Dingo509 Dingo509 is offline
the rears snap right on, the latch rods, the holes for the retainers etc. everything bolts up except the 2 big screws that hold on the armrest need to be relocated.
the fronts that's another story, the inside handle is in the wrong spot and the rods are different length i hav swapped the rear in my 91 and i am going to get the fronts to work, but im now thinking that it might be easier to swap the whole front door.
I already swapped on power heated mirrors from a 99 but swapping the hole door will also give you the tweeter location (can me made to fit 96- but doesn't look as good) plus the damn wing window is gone so you can actually see the mirrors.
Dingo
95 motor wont fit my 93 creed4017 Modified Tech Discussion 7 December 7th, 2004 17:01
33s fit fine! BillR Modified Tech Discussion 10 April 28th, 2004 22:51
No-Slip in 8.25 - C-clip fit problems? NN4S Modified Tech Discussion 8 March 11th, 2004 11:05
96 headlights and hardware fit a 87? mark268 OEM Tech Discussion 3 December 7th, 2003 14:43
How much lift to fit 29X11.5 R15s? btl_fed_xj Modified Tech Discussion 17 June 6th, 2003 14:34
