Old November 26th, 2006, 01:06
MYXJ22's Avatar
MYXJ22 MYXJ22 is offline
case of the dissapearing diff oil
My 8.8 is sqealing bad, everytime I pull the fill plug I see its low. So I spend $15 on a quart of gear oil and the diff takes the whole thing. I put my finger in just a little bit and its full. A week later, I repeat the process. There are no leaks under the diff or from what I can tell, coming out the axle tubes. Ideas?
Old November 26th, 2006, 02:22
Steve F's Avatar
Steve F Steve F is offline
Re: case of the dissapearing diff oil
Vent tube and up into the chassis rail? It can hid a fair bit up in there.
Cheers
Steve
Old November 26th, 2006, 07:58
Blue XJ's Avatar
Blue XJ Blue XJ is offline
Doesn't really help fix the probelm, but stop buying $15 a quart diff fluid for now.
Old November 26th, 2006, 10:28
MYXJ22's Avatar
It calls for 75-140 fully synthetic for LS. Can I substitute for another gear oil?
Old November 26th, 2006, 10:38
railroadjeep's Avatar
railroadjeep railroadjeep is offline
Have you pulled the cover? If your oil's gotten that low and it started squealing, you might want to make sure you didn't screw up your bearings, gears, etc.
dissapearing coolant jayuu OEM Tech Discussion 14 May 1st, 2007 15:29
lift, axles, t-case, driveshafts,wheels and tires,diff skids, a-mechanic For Sale: Private Party Only. XJ ITEMS ONLY 32 September 18th, 2006 12:26
Diff and t-case vacuum lines? Did Search. JT Spencer OEM Tech Discussion 5 September 1st, 2004 17:50
leak in front diff after I put on diff skid plate lapaul Modified Tech Discussion 3 April 14th, 2004 18:04
Diff case speader????? RCP Phx Modified Tech Discussion 12 November 10th, 2003 14:59
