Old November 9th, 2003, 12:21
RCP Phx RCP Phx is offline
Diff case speader?????
Im getting tired of fighting carriers in/out!I heard you can actually break a housing with a spreader?If you are using one how much are spreading the housing and how/where are you measuring?
Old November 9th, 2003, 13:00
XJoachim's Avatar
XJoachim XJoachim is offline
Exclamation
Don't spread the housig more than .015" !!!! Measure with a dial indicator comparing right and left side.
Old November 9th, 2003, 14:11
Beezil Beezil is offline
Member #Nay
you should not have to fight a carrier out.
are you using the rag or wrench trick?
never try to pry out a carrier
Old November 9th, 2003, 14:16
Out is usually the rag method,in is usually the BFH method!
BTW:I havent had or used a spreader yet,Ive been doing it the hard way.Im thinking about making one if it will help!
Old November 9th, 2003, 14:36
OT's Avatar
OT OT is offline
Hey B. Please explain rag and wrench trick. Is the rag trick when you wrap a rag around the carrier and tie a knot and twist a rod or something until it pops out, kinda like a 1st aid tourniquit?
Old November 9th, 2003, 15:50
Member #Nay
get a rag about as big as a sock...
kinda ball it up a little, and let the r&P "eat" the rag as you turn the pinion.
you may hafta put a wrench on the pinion for more "persuasion" but the rag will push the carrier out as its being "eaten"...
works well, and I usually use it if the wrench-at-12oclock trick doesn't push the carrier out enough
Old November 9th, 2003, 16:59
bottleworks's Avatar
bottleworks bottleworks is offline
What axle are you working on?
Old November 9th, 2003, 17:34
Im currently doing my D44 w/ ARB but Ive got a D30 to do next.
Old November 9th, 2003, 17:49
JP tech JP tech is offline
Don't use a case spreader, for install or removal. I rebuild diffs for Jeep and have found that when the housings are spread they never return back to the original position. Jeep is having lots of problems with the way Dana is setting up the diffs, mostly due to excessive carrier preload. Yes, this is from spreading the housings prior to installing the carriers and a poor set up. Use two big pry bars and work the carrier out this way you won't damage or distort your housing. As for install you should work the carrier into the housing about 75% of the way by hand and the rest of the way using a rubber dead blow hitting both sides of the carrier back and forth. If you need any more force than that, Your preload is too tight and the bearings will fail. Hope this helps. Chris
Old November 9th, 2003, 20:54
Safari Ary's Avatar
Safari Ary Safari Ary is offline
The first and only time I tried the rag trick, I ended up with a rag shredded to pieces and the carrier still in the housing. Then again, it probably would have helped if I had removed the carrier bearing caps However even after I removed the caps it still shredded a rag and I ended it up prying out with a crowbar on the side of the carrier. Popped right out after that.
Ary
Old November 9th, 2003, 22:54
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Member #674
I have been told the main problem with the Dana differentials is the fact that they set up the ring&pinion before they press the axle tubes into the centersection. DC has been trying to get them to change the way they assemble the diffs for a few years now and Dana has been reluctant to change their process. This is the main reason DC is changing over to American axles in the full size trucks and also why the next generation Grand Cherokee will now have "corporate" axles.
I do agree that the case spreader is a bad idea. I use the wrench trick whenever I can't just gently pry out the carrier. Most of the diffs I rebuild have bad bearings and the carrier can be removed by hand if it doesn't just fall out once I remove the bearing caps.
Bryan
Old November 10th, 2003, 00:15
98XJ's Avatar
98XJ 98XJ is offline
Has anyone ever worked with Ford 9.75 (semifloat) rear end?
Carrier falls out by itself after removing bearing caps(just a gentle pull is needed). There is less that .001 of preload in 9.75 diff....Wild!
And shims are between bearing and housing, not behind bearing on the carrier.....Freaking weird setup!
Pit...
Old November 10th, 2003, 14:59
XJoachim's Avatar
I've just set up my D60 front and D70 rear and i would like to see how you could do this without a spreader I have done a lot of axles right now and the best results i received when i used a spreader.
Just don't exceed the .015" spread and you will have a perfect bearing preload and a durable setup.
transfer case woes,.. BILLXJ Modified Tech Discussion 15 May 24th, 2005 14:25
Transfer case spline count info wanted. lunghd OEM Tech Discussion 4 May 2nd, 2005 18:54
WTB front dana 30 diff guard for 90 xj in CA lapaul Wanted: Private Party Only 2 December 11th, 2003 13:27
Detroit Locker in 8.25 Diff TLange Modified Tech Discussion 1 May 20th, 2003 07:28
..NP 231 transfer case studs,.. BILLXJ Modified Tech Discussion 4 May 8th, 2003 12:06
