Old May 21st, 2020, 13:31
deeretech129 deeretech129 is offline
2.5 --> 4.0 Swap
Hello,
I have two '96s, one is a Rusty POS with a 4.0 and AW4. I just bought a clean roller for cheap, 2.5 and a 5 speed. You see where this is going.
I would just like some clarification and possibly some advice, it sounds like most things will be plug and play seeing as they both are the same years. The biggest challenge that I can see is swapping over the cooling package and swapping the transmission. From my understanding, I will have to move the motor mounts somewhat and I will have to swap the grill and a radiator support and some other things to get the cooling package and headlights to work properly. It also appears likely I will have to swap the hood or at the very least the hood latch assy. I will keep the 4.10 axles. (perfect for 31's or 33's).
Are there any upgrades/resealing/tune up items you recommend also?
Old May 21st, 2020, 14:22
old_man's Avatar
old_man old_man is offline
Re: 2.5 --> 4.0 Swap
Originally Posted by deeretech129 View Post
Hello,
Motor mounts should just bolt up.
I had to swap the hood and front sheetmetal holding the radiator and headlights when I did this with an 85. I don't know how this might differ on the other years.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old May 21st, 2020, 19:37
Hello,
Was the sheet metal bolt in or did it require some welding?
Old May 26th, 2020, 19:55
ILLXJ's Avatar
ILLXJ ILLXJ is offline
On a 96 you shouldn't have to swap any sheet metal. I did the swap on a 87 MJ & everything bolted in.
JIM.
Originally Posted by monkeyevil
Brian is just a puppet in my corporate empire. I like to give him little tasks to keep him busy and feel important... like talking to Mr. Hale on the phone
Old Yesterday, 08:55
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
84-86 pre-date the 4.0 and as such they only accomodated the 2.5 and 2.8 (GM V6) without modifications.
Jeep modified the metal in 87 when they introduced the 4.0, and since both donor and recipient in your case are post-87 (and the same year), mechanical fitment shouldn't be a problem.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 07:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 22:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 08:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 12:40
