Old June 12th, 2018, 20:04
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
What year steering column swaps into what?
Just needing some clarifacation. What years swap into what? I've read 90-91 can only swap in same years. Read that anything pre 94 is a direct swap. Vehicle in question is a 90 ax15 with the HO. Wanting to swap in a column from a 93 AW4.
Cheers
Old June 12th, 2018, 22:09
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: What year steering column swaps into what?
Other than potential minor differences, should be plug n pray.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old June 13th, 2018, 05:53
smokeyyank's Avatar
XJholic
Does it matter if the 90 is a Renix? Basically asking for a friend who is wanting to buy my column from my 93.
Old June 13th, 2018, 10:32
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Same for 87-94. Then the early airbag models 95-96. Then 97+
Old June 14th, 2018, 10:12
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
It's not quite the same from 87-94. 91-94 use the Chrysler double sided ignition key that's shared with the doors. I'm not sure if 90-down cylinders and stuff will fit.
Those year breaks 1990JEEPXJ gave are otherwise good. No idea what 84-86 used, probably similar to 87-90 but I've not seen enough to be sure.
Remember that column shifted auto ones may be different for 3 speed vs 4 speed autos.
Also the ignition switch is different on straight and tilt columns, but that's not a big deal.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old June 18th, 2018, 07:25
1990JEEPXJ's Avatar
Yes the key is different after 91-94. I got lucky when I snagged a 94 column from the JY as it still had the key in it. But they are otherwise plug and play
Old June 18th, 2018, 18:29
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
84-94 are essentially the same column with a few differences.
I984 is unique because it the last year of a certain amc key design, 85-90 are basically the same depending on options like tilt. Key change in 1991 and it was different in some respects from the 80s XJ, something in the 91-94 years was different in removing and replacing the key cylinder. I think it was a 94 column i put in a 91, swapped the key cylinder out with some difficulty,’mostly because all the wright ups were on the 80s cylinders. The guts of the columns remain the same 84-94, if you have the key no reason a 94 column wouldn’t work in a 84 XJ.
Old June 19th, 2018, 11:10
smokeyyank's Avatar
XJholic
Awesome! Thanks for the info.
Old June 26th, 2018, 15:53
Overland's Avatar
Overland Overland is offline
I pulled the lock cylinder from my 86 2.8/AX5 and with square key and release lever, then replaced it with a cylinder from a 92 with 4.0/AW4. It's a Saginaw column either way. The early cylinder secured with a screw, the later with a tab in slot. The column has accommodation for both.
Now using late model door lock cylinders from a four door in an early two door required linkage modification, but now I have one key in my AMC XJ.
The only notable differences with early/late or 3/4 speed autos would be the shift interlock cable.
Old June 26th, 2018, 19:05
Jeep Driver Jeep Driver is offline
https://www.youtube.com/watch?v=qdn8uUTAyfQ
Steering Wheels Swaps Eddy_AL Modified Tech Discussion 0 October 17th, 2010 13:15
1992 (chrysler?) steering column in 1988 XJ (originally GM Column), possible? JonnyRo Modified Tech Discussion 4 December 28th, 2008 06:32
Steering column help!!!! 89cherokeexj OEM Tech Discussion 13 September 5th, 2008 22:00
in need of steering column Gerr Wanted: Private Party Only 2 April 28th, 2005 06:49
