Old June 12th, 2018, 01:32
standley20 standley20 is offline
3.7 swap?
hey guys don't beat me for this but my 2.5 is about dead and im looking for a cheap swap. I have searched and nothing on a 3.7 and nv3550 swap. is it just a to costly of a swap or is the 3.7 a dud? my jeep is gonna be on 35s soon and just wanted to get some feedback. thanks.
Old June 12th, 2018, 01:39
RCP Phx RCP Phx is offline
Re: 3.7 swap?
What year is your XJ? What would you do about engine/transmission electronics?
Old June 12th, 2018, 01:55
Re: 3.7 swap?
89 I can get a killer deal on a liberty complete running and driving for $800 it was offered to me and been thinking it would have to a little more peppy than the whooped 2.5
Old June 12th, 2018, 02:13
Re: 3.7 swap?
It might be better than the 2.5, but all your money is going to go into the custom install. What would you do about the electronics?
Old June 12th, 2018, 02:27
Re: 3.7 swap?
everything I would need to swap is in the running and driving vehicle I would just use the harness, manifolds, pump ect. I guess im really wondering is it worth being the liberty fell in my lap I don't mind fabbing my own mounts and exhaust maybe should reword my question from cheap swap to worthwhile swap
Old June 12th, 2018, 03:50
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 3.7 swap?
Just because you have a cheap donor, does not make it a good swap. You don't read much about 3.7 Liberty swaps because they just don't get done.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old June 12th, 2018, 07:49
trippled trippled is offline
Re: 3.7 swap?
Don't waste the time. 3.7 is junk.
Old June 12th, 2018, 08:17
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
Re: 3.7 swap?
Wife has a KJ....while it's been decently reliable and is easy to work on, it's pretty gutless. Personally, I'd swap in a 4.0 if you need to.
Old June 12th, 2018, 08:41
denverd1's Avatar
denverd1 denverd1 is offline
Re: 3.7 swap?
AX5?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old June 12th, 2018, 09:49
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
Re: 3.7 swap?
This
If youíre gonna go through the time, effort, and expense of a swap, make it a worthwhile one.
Like an LS
John V.
Director at Large
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old June 12th, 2018, 20:42
JeepNoob JeepNoob is offline
Re: 3.7 swap?
Agreed. NV3500/3550 is pretty good, 3.7 is a turd, but they are reliable... right up until they blow a head gasket. Swap in a 4.0.
Old June 14th, 2018, 18:32
bigdaddyjlove bigdaddyjlove is offline
Re: 3.7 swap?
Just dumped my daughter's liberty and put her back in an XJ. I am not a fan of the 3.7. Complicated and expensive to work on for 200 hp. Replacing head gaskets cost me over 1k and I did the work.
Old June 14th, 2018, 18:53
Czjeeper Czjeeper is offline
3.7 swap?
3.7ís are complete garbage. I highly recommend you do something else.
Old June 15th, 2018, 10:27
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: 3.7 swap?
2.8L CRD (Diesel)?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 16th, 2018, 12:31
LLLux31 LLLux31 is offline
Re: 3.7 swap?
Originally Posted by Rob Mayercik View Post
2.8L CRD (Diesel)?
I would stay away from the CRD unless you plan on dropping $$$ on making it reliable first.
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 07:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 22:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 08:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 12:40
