Old June 8th, 2018, 05:23
old_man's Avatar
old_man old_man is offline
Anybody found a good alternator upgrade for Renix?
My alternator is getting a little long in tooth and was thinking of upgrading when switching. Remember this is a Renix and has the built in regulator so swaps for the later models are not as simple.
I was just hoping somebody found a better replacement.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old June 8th, 2018, 12:40
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
Re: Anybody found a good alternator upgrade for Renix?
Can you use a higher output Delco CS-130 alt? These are 105A GM alternators from 1986 to 1996 for their cars and pickups?
Old June 12th, 2018, 16:59
#S194's Avatar
#S194 #S194 is offline
Sierra Chapter President
I used a remanufactured 100 amp Remy when I replaced mine. Part # 20352, ordered from Rock Auto. So far so good.
Originally Posted by GordoSmasho View Post
Tim's junk is impressively beefy. TWSS
Old June 13th, 2018, 09:07
Sean778's Avatar
Sean778 Sean778 is offline
I had my local alternator shop rebuild my alternator with the guts from a cs144. They had an old boxed kit that they had in stock, I donít know if thatís something thatís still available commercially or not. It puts out over 140 amps, and works as good as new. If I was in the alternator market again, Iíd call around and try to find someone to do it the same way. It was not much more money than a regular alternator rebuild, and certainly worth a few phone calls.
Old June 16th, 2018, 11:32
Hypoid's Avatar
Hypoid Hypoid is offline
My Limited has a 100 Amp alternator for all the whistles and bells that came with that trim level. It's a cheap bolt in.
Flores told me about using a CS-130 (140 Amp) alternator out of a Chevy truck. I brought one home from the junkyard. The lower mounting tab is thicker, you can't bolt that to the stock mounting bracket. Making a lower bracket for the bigger case actually appears simple and straightforward. It's on my "someday" list of projects.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old June 16th, 2018, 11:33
Hypoid's Avatar
Tom, I know of one rewind shop in Wheatridge.
Old June 16th, 2018, 15:13
old_man's Avatar
Thanks for the connection. Being away from Colorado, all I can do is plan and get ready for the short durations when I am home.
Right now I am in DC working for Northrup Grumman and a new satellite the STPSat-6. I just finished up on a surveillance satellite for Harris in Rochester NY.
Hope to be done and back home for Christmas.
Sure miss all you misfits and nut cases.
Old June 17th, 2018, 10:10
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I'm running the 20352 100 amp as well. Picked a couple new old stock up on rock auto a few years ago.
Alternator upgrade 89 2.5L? hot_rod_hooligans Modified Tech Discussion 2 March 3rd, 2016 11:44
JunkYard Alternator Upgrade Renix and HO help! Rags Modified Tech Discussion 14 June 17th, 2012 18:36
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 21:21
Renix Alternator Upgrade Questions. I have searched! zeroforhire OEM Tech Discussion 13 January 19th, 2010 23:30
