Old January 22nd, 2008, 14:03
92jeepxjOR's Avatar
92jeepxjOR 92jeepxjOR is offline
broken cross member stud help
I'm trying to put in a transfer case drop kit and I was trying to pull out one of the studs I was using 2 nuts as a jam nut to get it out and now the stud just spins and moves side to side and I need help trying to figure this out cause I don't want to have just 3 bolts holding that cross member. if anybody has any suggestions please help
Old January 22nd, 2008, 14:05
Ramsey's Avatar
Ramsey Ramsey is offline
Re: broken cross member stud help
You broke the weld inside the frame. Got to cut an access hole in the side now.
Old January 22nd, 2008, 14:16
92jeepxjOR's Avatar
is that going to weakin the frame a lot right there?
Old January 22nd, 2008, 14:20
ZacSquatch's Avatar
ZacSquatch ZacSquatch is offline
No, just cut a 1"x2" square hole and or use a 1" hole saw, just enough to get a box end wrench in there.
Old January 22nd, 2008, 14:32
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Support Your Local Trails
Just drill it out and tap the hole for the next larger size bolt.
MWC Vice President
1995 XJ Sport Mallcrawler build
2009 Chevrolet Suburban K2500 6.0L/6L90
Old January 22nd, 2008, 14:34
ZacSquatch's Avatar
How the hell do you drill out a nut that is spinning freely? Not to mention it has a stud stuck in it.... What ya smokin man
Old January 22nd, 2008, 14:54
92jeepxjOR's Avatar
I think I'm just going to go with the hole saw then just use a nut and a bolt
Old January 22nd, 2008, 14:56
Ramsey's Avatar
Probably your best option, a washer against the inside wouldn't be a bad idea either.
Old January 22nd, 2008, 15:22
ZacSquatch's Avatar
Also, after you do that, you may be able to find a rubber drain plug the right size to fill the hole of you want. I know Tim has one with his.
Old January 22nd, 2008, 16:32
IllianaXJ's Avatar
Must have missed the spinning freely part.
Proceed with the cutting.
MWC Vice President
Old January 22nd, 2008, 22:25
XJ Beater's Avatar
XJ Beater XJ Beater is offline
take big hammer, smash the stud till it pops into the frame rail, now drill and tap the hole, worked for me
Old January 22nd, 2008, 22:55
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
If he's like me, the thought of having something loose floating around in the unibody rail would be enough to make me cut a hole in the side to get it out
Old January 22nd, 2008, 23:01
Ramsey's Avatar
the frame rail is so thin i really doubt tapping it would give you enough bite.
Old January 22nd, 2008, 23:06
Blaine B.'s Avatar
Could weld up a nut if possible?
Old January 22nd, 2008, 23:08
CanMan's Avatar
CanMan CanMan is offline
If you cut a big enough hole in the frame or the floor above, you could weld a nut in I suppose.
Take Ramsey's advice, cut hole, add nut inside, bolt from bottom, call it good.
Broken Wheel Stud DaveD912 OEM Tech Discussion 1 August 11th, 2007 12:22
BROKEN WHEEL STUD xcm Modified Tech Discussion 29 April 9th, 2007 09:19
Broken lug stud...how safe? bustednutz OEM Tech Discussion 11 June 6th, 2006 16:36
Broken wheel stud! bubbadabulldawg Modified Tech Discussion 6 October 31st, 2004 06:02
Rusty's Cross Member and 1" drop cross member Kejtar Modified Tech Discussion 13 April 13th, 2003 21:50
