Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
View Poll Results: Wishbone Or Stay the same? | |||
Wishbone Setup |
8 | 13.56% |
Short Arm |
24 | 40.68% |
Neither |
27 | 45.76% |
Voters: 59. You may not vote on this poll |
Thread Tools | Display Modes |
hould i put in a wishbone setup in the front of my Daily Driver? Or SHould i stay short arm, the way i am now.
#2
Re: Wishbone???
ADjustable short arms, maybe some drop brackets or why not some long arms!
#3
Re: Wishbone???
No.
If you have to ask, it's probably not the right project for you. |
#4
Re: Wishbone???
wishbone? why the hell would you do that?????????
#5
Re: Wishbone???
get an old civic and you'll have 4 wishbones up front and better mpg.
#6
Re: Wishbone???
there was a recent thread showing the results of a failed wishbone setup on the hiway.
not that the idea isn't good, or the design was flawed, but it seemed like it wasn't meant for stresses normally encountered on the road at high speeds. That being said, as its stated above, if your asking, and its your daily driver I would think NO. I'll build bumpers, rock rails and such, but I don't mess with controls arms and steering, one should know ones limits, skill and knowledge level. |
#7
Re: Wishbone???
He's not building it, he's buying it.
#8
Re: Wishbone???
you can buy wishbone front suspensions for an XJ?
ya learn something new everyday. |
#9
Re: Wishbone???
Its you DD brotha you out yo damn mind? Sorry ghettoness came out of nowhere
#10
Re: Wishbone???
ok im in a good mood so instead if interweb beating the hell out of you ill type this out.... ditch any notion of the wishbone it isn't a streetable setup.... because the suspension will cycle straight up and down now as opposed to in a gradual side to side caused by the panhard you will experience bumpsteer.... ie as the suspension cycles up and down over bumps and whoops in the road it will steer itself, also as you steer with pressure on your tires (ie trail use) it will push the body up and down and lessen steering deflection... just out of curiosity where are you buying a 'bone setup from?
#11
Re: Wishbone???
See, I voted to go wishbone because I wanted to see it!!! haha
#12
Re: Wishbone???
honestly for a daily driver stay close to stock, because when you break some thing you want to be able to get parts asap. adjustable arms and drop brackets work pretty well and keep the geometry simple
#13
Re: Wishbone???
Its called "Wishbone" Because after you put it there you wish you hadnt because it boned you by failing.
Sorry, couldnt resist. ![]() |
#14
Re: Wishbone???
haha NO. Don't put a wishbone on your XJ are you CRAZY??? Thats just insane.
#15
Re: Wishbone???
all the tacoma and ranger guys want to do SAS for better flex and offroad ability, so why would an xj owner want to go to wishbone, unless it was for jeepspeed. if anyone has an intelligent answer to that i'd be delighted to hear it. if you're trying to improve on-road handling...think of it as upgrading a d35. you just don't do that. as previously stated, get a civic and you'll have 4 wishbones.
Thread Tools | |
Display Modes | |
The Wishbone MIGHT work! lotza PICS | Beezil | Advanced Fabrication and Engineering | 76 | October 10th, 2006 08:53 |
Front Wishbone Help | JeepFreak21 | Advanced Fabrication and Engineering | 54 | April 13th, 2004 07:37 |
pics for one smooth...wishbone | Beezil | Modified Tech Discussion | 10 | September 23rd, 2003 02:22 |
the wishbone project-waayy too many pics- | Beezil | Advanced Fabrication and Engineering | 30 | August 26th, 2003 10:35 |
The Wishbone project | Beezil | Modified Tech Discussion | 28 | August 7th, 2003 19:26 |
