OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Quick question on transfer case lever
Ok - silly question here. But I'm trying to reassemble my shift lever area on my 1991 5 speed. I just had a shop put in a new clutch, and its all apart. The light for the transfer case lever position indicator is just dangling off to the side. I for the life of me cannot figure out where it goes by the lever. Been searching for an hour for a pic or vid or post but no luck. I'm not sure if a bracket or something is missing now but I don't see how it attaches. I assume the bulb unit attaches directly to the lever, underneath the metal bracket. But I'm lost as to how or where. Any tips greatly appreciated, lol
thx! |
#2
Re: Quick question on transfer case lever
This help? You sure it's not the light for the transmission shifter you're looking at?
#3
Picture is from https://www.cherokeeforum.com/f2/4wd...-light-128357/
#4
Oh wow man ok got it. That side piece/tray part of the plastic shifter cover there where the bulb screws in completely broken off on mine. I see the screw hole there too, hence the hole in the bracket beneath. Its snapped off so clean it looks like it was never there. THANK YOU. I need to get a new cover. Hopefully there are new ones or I'll hit the junkyards. I'm assuming I need to find a 5-speed one though, not ez...
that was helpful.. thx!! |
#5
The center console bases are the same between automatic and manual. It's just the bezel piece that snaps in around the trans shifter that changes. 1987-1993 XJs are interchangeable.
Comanches swap as well, with the minor difference being the ash tray on the back side. I have the full length XJ center console in my MJ that started with a bench seat and the small console. |
#6
Ya. hard to find. not much on the google machine..
#7
thx Lawsoncl- ya ok I see, just that middle insert is different. I have that. Just need the big piece that the inserts snap into. Not much out there.. seem like someone should be making a new one. I'll hit the (few) yards around here I guess..
Thread Tools | |
Display Modes | |
Brake Upgrade Question (with Transfer Case Drop BONUS Question) | NateEnos | Modified Tech Discussion | 9 | April 13th, 2011 14:41 |
Transfer case lever bushing replacement Q | Techno Duck | OEM Tech Discussion | 2 | November 13th, 2010 17:51 |
NP242 transfer case seal - quick question | auswee | OEM Tech Discussion | 8 | August 1st, 2010 10:36 |
Quick Question on transfer cases. . . . | SBrad001 | OEM Tech Discussion | 4 | February 7th, 2006 15:06 |
Transfer case quick question...help? | Mngreen | Modified Tech Discussion | 4 | July 20th, 2005 18:50 |
