Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old September 19th, 2020, 12:17
Spencer0428 Spencer0428 is offline
1990 XJ WILL NOT START- Help please
So, I’ve got a 1990 XJ that I’m about to light on fire.
The Jeep will turn over, it has spark, and it is getting fuel. It was just running a few weeks back and now it will not fire up anymore. After I try to start it, when I turn the key back from the “crank” to the “run” position, the injectors start to fire uncontrollably.
I’ve checked the CPS, (stator/camshaft position sensor), and the ECU.
I have 10 Xj’s here at the house and have never had this issue. Starting to think there is a short somewhere.
I’ve got a video if the injectors pulsing but can’t figure out how to post it.
Any help would be greatly appreciated
Old September 19th, 2020, 12:32
Re: 1990 XJ WILL NOT START- Help please
Also, the only light that comes on in the diagnostic/idiot light panel is the “BRAKE” light. It is only lit up while the key is switched to the “crank” position and the starter is turning the motor over.
Rate This Thread:
1990 XJ Won't Start! :( AnotherBoss OEM Tech Discussion 1 April 25th, 2010 21:45
1990 XJ WON'T START.... HELP ME PLEASE TRANTHAM OEM Tech Discussion 2 October 2nd, 2009 13:37
parting out 1990 xj start over allinked25 Arizona For Sale/Wanted 8 May 18th, 2009 09:39
yet another no start 1990 Lightfoot OEM Tech Discussion 3 December 13th, 2008 05:42
1990 no start mcdermott6555 OEM Tech Discussion 5 October 22nd, 2008 02:01
