Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old December 17th, 2022, 10:12
1tgs2019 1tgs2019 is offline
Swap from HELL!!!
So I decided to do a swap on my daily driver before the summer began. A 1998 tj. I took out the 2.5 manual and swapped in a 94 zj drivetrain. Which is a 4.0 and 42re. I ended up having the motor, transfercase, pcm, and tcm. Which I thought would be plenty to get it going. Boy was I wrong..
So it's been six months and I'm still having technical difficulties. I've bought a radiator, complete engine wiring harness, and another pcm. As well as a few other things I'll touch on in the words to come.
To make a long story short, I have it the the point where it fires up but immediately kills the injector pulse. After a few weeks of searching and reading on the web I have came to the conclusion that it's the pcm not having can bus communication with the alarm module.
I'm flat broke and almost out of hope. I buy a new used general pcm without security from beards Midwest jeeps. Theses guys have saved my bank on parts for this swap. Turns out it is not the problem.
I read somemore about bypass modules. And was actually going to the junk yard to find a decent carb to try n get work when I came across a 91 xj Laredo. I bought the pcm and complete dash wiring for $20..
I am still using the tj dash wiring. My question is should I take it all out and swap in the xj wiring harness. Or should I try to separate the xj alarm module and wire it in to my current setup. Are the security modules plug and play? Or would I need to have my pcm flashed. Say I use the xj pcm, and dash wiring. Would my zj tcm communicate with it?
Sent from my T602DL using Tapatalk
Old January 3rd, 2023, 20:54
MAY POP MAY POP is offline
Re: Swap from HELL!!!
There is a fellow on the Jeep Forum called WATERLUVER he’s in the WJ section. He’s capeable of removing the Skim from some modules. Perhaps he can help.I woul think staying with the ZJ PCM would be best as it can talk to the TCM . He does good work fast and is in Indiana so close to Illinois. He could probably add your Vin to it if you need emissions. Or you get a PCM that does not have a Skim module from another ZJ
Ron
Old March 15th, 2023, 21:13
I have tried 3 different pcms. The only thing I haven't tried is a security bypass module. Is there a cycle of checks the pcm has to clear to run correctly? Like a preshift inspection on can bus. I know it's a long shot but I'm desperate.
ANYONE KNOW WHAT THE HELL THIS IS?? 1_Sick_XJ OEM Tech Discussion 14 April 15th, 2014 11:24
The water pump swap from hell old_man Non-Tech / Off Topic 22 March 6th, 2012 12:12
What the hell... BruceB83 Non-Tech / Off Topic 35 January 12th, 2008 14:47
99+ intake swap from hell; I need some help OCMI_Teddy Modified Tech Discussion 16 April 2nd, 2007 21:23
