Old March 14th, 2019, 15:41
Greenspan's Avatar
Greenspan Greenspan is offline
1" Wheel Spacers Q's?
My 2" OME lift should be done tomorrow on my 98 XJ D30 and C8.25. Planning on getting some 30x9.5 tires next. To prevent any rubbing and just improve the stance overall I plan to get these 1" wheel spacers too: https://www.titanwheelaccessories.co...-wheel-spacers
I don't want to get into the spacer debate here I just had a few questions.
1) They mention that if the stock studs are shorter than the spacer they will need to be grinded/cut down. I really don't want to have to do this. How long are the stock studs? Will 1" spacers be too thin? Anyone else run 1"? How thin can I go without having to do this?
2) For the XJ so I want hun centric spacers or not?
3) Anyone have any experience with Titan? Looks reputable and they are very reasonably priced
Old March 14th, 2019, 16:46
Scrubber3 Scrubber3 is offline
I've never had an issue with 1 inch spacers and lug studs being too long or short or whatever.
You don't need hub centric, but it's easier to get the wheel back on straight with hub centric.
You could always get a set of steel rims with a 4.5 inch backspace... dirt cheap! Probably less or as much as a set of spacers and not have to worry about the extra hassle of spacers. I got a brand spanking new set of pro- comp crawlers for $46 each rim and free shipping on Amazon. If you look around you can get them for less than $40 each im sure of it.
Old March 14th, 2019, 20:55
Greenspan's Avatar
Re: 1" Wheel Spacers Q's?
Ok thanks for the input.
Im kinda a special case, I have ten (10) stock wheels total. I got a good deal on an extra set of 5. I plan to run an extra spare tire (4+2), and plus Ill have an extra set of wheels (4) that I can keep my currently in good shape street tires on or put snow treads on if I want. Those spacers are $90 for a set of 4, thats a lot less than 10x of the cheapest steelies, or even 6x. Plus, I like the stock wheels.
I want to give spacers a shot, if they end up being terrible Ill buy new wheels later its not a big loss. So that's why I don't want to debate spacers vs backspaced wheels, and just want to know if those spacers will work.
Old March 15th, 2019, 01:28
Yeah, you should be good to go. I've run 1 and 1.5 inch spacers before without issue. The price on those is the best I've seen anywhere.
Old March 15th, 2019, 12:16
srb531 srb531 is offline
most high quality spacers are 1 1/4" , that way theres no worry of needed to grind any stud length off. i use G2 spacers , dont cheap out on spacers
Old March 15th, 2019, 12:20
btw , 55.00 for 2 spacers is cheap, good high grade spacers are more like 50.00 each. cheap ones are known to crack and break in half. research it a bit, before you buy.
Old March 15th, 2019, 12:33
Greenspan's Avatar
Yeah Im trying to do my research here. It sounds like scrubber has run 1" spacers no problem, so do I really need 1.25"? Has anyone tried to run 1" and had a problem?
What's the difference between "cheap" spacers vs "expsensive" spacers. Do they use 6061 vs 7075 aluminum or something? Buy expensive stuff because its better because its more expensive doesn't really help. Has anyone run the Titan spacers and had a good/bad experience?
XJ/TJ/YJ 1.5" Wheel Spacers jhendry51 NAC Classifieds 0 July 18th, 2014 10:55
1.25" wheel spacers 5x4.5 paulhead For Sale: Private Party Only. XJ ITEMS ONLY 0 January 16th, 2009 20:25
RE XJ 3.5" Coils, 2" Poly Spacers, Black Steel wheel woodkrawler For Sale: Private Party Only. XJ ITEMS ONLY 5 January 4th, 2007 09:45
