Old February 2nd, 2007, 14:05
maine96xj's Avatar
maine96xj maine96xj is offline
Motor Mount Replacement (searched)
I searched but could not find definate instructions to replace a motor mount, mines broken and its causing fan to pitch into the fan shrowd and make an aweful noise.
Can someone provide me with step by step replacement instuctions for the drivers side? how do i get around the intake? Etc. Etc.
Thanks you very much,
Owen
Old February 2nd, 2007, 15:19
CanMan's Avatar
CanMan CanMan is offline
Re: Motor Mount Replacement (searched)
It is very easy to do it from underneath. Be sure to support the engine though.
Old February 2nd, 2007, 16:20
Bones's Avatar
Bones Bones is offline
Which side? If it's pitching the fan towards the rad I would guess it's the left (driver) side. The mount on the driver side is fairly straight forward. Brace the motor using a jack and block of wood under the sump section of the oil pan (to spread the weight of the motor as much as able). Raise the block/motor slightly. The front of the Jeep will rise as you take the weight of the engine off the suspension so how far to raise the motor is the hardest part. Remove the long bolt that passes through the engine mount bracket and the mount. Start with very little lift on the motor and raise it a bit at a time until the bolt will slide out. Once the large bolt is out you can remove the two under the mount (frame side attachment) and lift the bad mount out. Replacement is the reverse of removal.
The passenger side is similar but you have to contend with the oil filter and bracket and depending on year the AC drier that will need moved/removed to get the long bolt out.
Depending on what you do with your Jeep you may want to look into some aftermarket mounts. I run M.O.R.E.'s rubber mounts and would recommend them strongly if you run big tires, hot rod around, or off road. If it's a stock daily driver the stock mounts will work fine and give less transmitted vibrations. Poly mounts will rattle your teeth and IMHO aren't any better than the ones I run.
As a side note be sure to check the opposite side mount and the tranny mount. If one is at the end of its service life the others probably not to much better.
Bones
Random picture:
Old February 2nd, 2007, 18:46
Hudson Bend Hudson Bend is offline
x2 with what Bones says above plus remove the air filter box to give you more room to work. One at a time. Replace both motor mounts and the one anchoring the tc at the center crossmember. Do this and you can stop worrying about when the next mount is getting ready to go. Jack up the engine carefully just enough to take the weight off one side, remove old and replace new, then do the other side. Use the wood to spread the force and not damage the pan. Check for gaps between the new mount and the bracket which holds it in place and shim(washer)if necessary. It's a dirty, sometimes knuckle busting project but one that is simple and can go quickly. Can being the key word since there is no guarantee. Alien small hands would also be nice to fit in that crowded area on the passenger side.
Old February 2nd, 2007, 19:07
jeepinandy's Avatar
jeepinandy jeepinandy is offline
X3 I removed my air filter box too, made alot more room to work with.
Old February 3rd, 2007, 07:09
maine96xj's Avatar
excellent guys thanks, is it ok to run it for a little while till i have enough time off work to do it? how do i change the trans mount? jack up the trannly slights and remove the bolts? that easy?
im pretty sure im just gunna go with some stock mounts. it is mostly a DD i only take it down trails from time to time, and im not much for "hot rodding" around in my daily driver vehicles
Old February 3rd, 2007, 08:02
bcmaxx's Avatar
bcmaxx bcmaxx is offline
I wouldn;t wait too long, one bad mount will lead to more bad mounts, I supported the transmission while I dropped the crossmember, unblted the old mount, put the new one in and put the crossmember back up in.
Old February 3rd, 2007, 14:55
krelja's Avatar
krelja krelja is offline
jason @ jeepin.com com has a write-up on changing over to M.O.R.E motor mounts on his site. I recently did the M.O.R.E mounts and they are pretty easy. If you have a TC drop take that out 1st. You will be able to get the mounts out with the TC drop in but not back in. The M.O.R.E mounts are vibing a little bit right now but it is tolerable, and its getting better everyday. I used a 2x4 on the oil pan and it would out great. Oh yeah the bolts are not very tight at all
Old February 3rd, 2007, 23:09
kd5dwy's Avatar
kd5dwy kd5dwy is offline
Just posted a thread with detailed, step-by-step instructions on this...
Old February 4th, 2007, 13:38
CanMan's Avatar
Here is a write up on it. http://www.naxja.org/forum/showthread.php?t=906343
Old February 4th, 2007, 13:47
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Running with it very long will lead to a cracked exhaust header. Fix it now.
Old February 7th, 2007, 13:53
maine96xj's Avatar
Thanks for all the help guys. changed out the broken drivers side mount today, took about 45 mins to an hour. heres pics of the old drivers side mount...little scary
Old February 7th, 2007, 20:26
kd5dwy's Avatar
Mine had no rubber at all left across the top. No wonder that booger was dancing around in there...
You were due for a replacement. Did you go OEM style or aftermarket?
Motor Mount Help !! gmcelroy OEM Tech Discussion 1 November 26th, 2006 15:36
Searched motor compatability littlebluexj Jeep Street and Performance 10 April 17th, 2006 05:39
wierd THUNK tranny mount?searched aduke OEM Tech Discussion 15 September 29th, 2005 20:27
motor/tranny mount replacement writeup? siminsez01 OEM Tech Discussion 5 April 11th, 2005 11:27
Motor Mount Replacement Markm80521 OEM Tech Discussion 11 August 18th, 2003 13:50
