Old April 22nd, 2006, 07:21
ADVNTURR's Avatar
ADVNTURR ADVNTURR is offline
I worry when rattles stop
Oil change vacuum pump??
I just bought a used VW Golf TDI (so the XJ doesn't have to be a daily driver anymore) and I have been looking into various upgrades for it and found something interesting when I was looking at skid plates for the oil pan. Has anyone ever heard of or used a Pela Oil Extractor (http://www.pelaproducts.com/) before on their XJ to change the oil. I know it would work in the Golf but if it would work in my XJ too I actually might consider getting one so that I don't have to modify the skid on the Golf. Any thoughts or personal experiences with these products or similar please share.
Old April 22nd, 2006, 07:26
87manche's Avatar
87manche 87manche is offline
Re: Oil change vacuum pump??
sucking the oil out the dipstick tube is perfectly viable. Just make sure you get a pump that can handle 6 quarts.
Old April 22nd, 2006, 07:29
langer1's Avatar
langer1 langer1 is offline
The only thing I would think is at least some time open the drain so your sure you get all the dirt out with the oil.
Old April 22nd, 2006, 14:07
RichP's Avatar
RichP RichP is offline
Dirt sinks or settles out of the oil, the suction type will not get it all out, thats why you change oil when it's hot so it flushes out with the old oil...
Fuel pump change, any tips/tricks? R_Willis OEM Tech Discussion 2 November 29th, 2005 21:10
Smal Vacuum Pump Question... 5-90 Non-Tech / Off Topic 0 January 19th, 2005 22:21
Change axle fluid using a pump sprinkler1228 OEM Tech Discussion 8 September 27th, 2004 12:58
AC Manifold and vacuum pump BIGSLVRXJ Wanted: Private Party Only 0 August 10th, 2004 14:53
Differential Fluid Change with Extraction Pump BudTX OEM Tech Discussion 4 June 16th, 2004 18:55
