Old March 11th, 2004, 15:23
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Rear Shoulder belt Retrofit---89 4dr XJ
As much as I would like to swap my lift and axles over to a 99 XJ body......it's not in the cards right now, so I need to get some rear shoulder belts in place for my kids. I tried my Jeep parts contact, there is a TSB # on a rear shoulderbelt retrofit, but he's yet to come up with anything.
I'm wondering if anyone has pulled the hardware from newer XJ and performed the retro fit themselves.....if so, please share. I'm sure it involves chopping them out of a donor rig and welding in gussets and a trim swapout...........
TIA
Speak the Truth-Question with Boldness
Old March 11th, 2004, 15:48
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: Rear Shoulder belt Retrofit---89 4dr XJ
TIA
This was just discussed about a week or two ago. Hate to say "Do a search," but the only way to do otherwise is for me to do it for you. Thus:
"Do a search"
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old March 11th, 2004, 16:56
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
I hate to usurp a "do a search" comment, but long ago I thought about doing that to my 89 XJ and came up with p/n 4636414-rear shoulder belt retrofit kit. I don't know if that's still valid or not but maybe it will help. Other than that, uhhhh...do a search.
Old March 12th, 2004, 05:05
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
I thought about this and have not researched it yet but I plan on having a hoop built like rustys sells and have a shoulder bar for a 5 point harness on it. A little more expensive but worth the extra protection IMHO. And it will not be just a bar there will be at least something to the rear until I figure out how I want the front done.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old March 12th, 2004, 06:49
XJEEPER's Avatar
NAXJA Member # 13
"Do a search"
Ya ya ya.......found it using different verbage........and I had no idea that the rear belts weighed 10lbs....thanks Jes!
Rear Shoulder Belt Upgrade RedBluff Modified Tech Discussion 3 March 6th, 2004 23:38
Will 6" coils and 4" rear work on 90' XJ? ShipleyCSA Modified Tech Discussion 4 March 4th, 2004 06:17
need some adive on replacing the rear main on my 90 xj jeepster OEM Tech Discussion 9 March 3rd, 2004 09:34
XJ and garage door opener issue? C_M Non-Tech / Off Topic 3 December 7th, 2003 17:09
Wanted: rear seat belt DaveD in Canada Wanted: Private Party Only 3 July 21st, 2003 18:41
