Prev Previous Post   Next Post Next
Old March 10th, 2004, 19:26
jchampoux's Avatar
jchampoux jchampoux is offline
broken stud, lower shock mount
For the archives:
While changing my (96) rear shock I twisted off the stud from the lower mount. To fix it I cut the stud flush with the mount with a Sawzall then ground it smooth. I then center punched where the stud was and drilled it out with a 31/64 bit. I used this bit because it was the closest I could get to a 12mm hole.
The OEM stud is around 5/8 ( or the nearest metric number) A 5/8" bolt fits snugly into the rubber bushing of a OEM shock, but I didnt have the drill or the bit to drill out a 5/8" hole so used a metal tubular bushing that inserts into the hole of the shock (to keep it from being compressed too far) and a 12mm (grade 5) bolt fits it perfectly. I ground about 1/8" off of the tubular bushing to provide a litttle more compression, I then used my new bolt, original washers and a new nut with some blue loctite. All seems well. I may tack weld the head of the bolt to the other side of the bracket if it seems like it needs it, but for now, removeability is fine with me.
Between the pad that the shock mounts against and the hemi-spherical head of the old stud the bracket ends up being about 1/2" thick so I used a 3" bolt.
JIm
broken lower shock mount stud bolt
Broken Rear Axle Shock Mount, How to fix? John - JeepsWorld.com OEM Tech Discussion 1 October 25th, 2003 19:36
broken shock mount jjchgo OEM Tech Discussion 4 August 28th, 2003 06:52
rear lower shock mount conversion Kejtar Modified Tech Discussion 17 August 27th, 2003 00:30
Rusty's Track Bar Frame Mount - Broken!! rbarton Modified Tech Discussion 12 August 25th, 2003 10:23
shock conversion mount kit crazy4mopar For Sale: Private Party Only. XJ ITEMS ONLY 1 May 30th, 2003 12:33
