Hoarding 101
RCP Phx
Phoenix,Az
Since factory parts are getting hard to find and getting pricey, I've been stocking up on things. I love the expiration date on the battery box! I've got at least 2 of what I call critical items. I had another battery box but along with a few other things I used it on "lil sis".
1 - battery box
1 - oil filter adapter
2 - oil adapter bolts
2 - crank sensors
2 - cam sensors
2 - throttle position sensors
2 - idle air controllers
2 - map sensors
3 - intake air temp sensors
2 - coolant temp sensors
2 - oil pressure sensors
Add a heater box and a steering column.
For those of us in road salt territory:
1 complete carpet set
2 complete front clips
assorted fender flares and brackets
2 sets of not rusty at all doors
2 tailgates
2 hoods
2 complete sets of seats
I used up my spare front and rear axles so I need to get more.
Re: Hoarding Mopar 101
Corrected title as I have a copper core heater core and a ton of other stuff that isn't Mopar. The objective here was to accumulate "Mopar" parts before they are totally unavailable.
Slowly doing the same.
Mopar Fuel Pump
Mopar CPS
Mopar TPS
Mopar Coolant Sensor
Mopar Oil Pressure Sensor
2 Mopar Oil Adapter O-Ring Kits
2 Mopar Vacuum Hose Elbows for the Map Sensor
New rear Mopar Mud Flaps and a complete set of used ones.
Extra hood, doors, hatch, fender flares, fender flare brackets, privacy glass all used.
Plenty of Camel interior parts all used.
A small collection of used wiring harnesses that I have been accumulating.
Extra used overhead consoles for the computers.
Second set of used factory running boards just in case.
Also sorts of stereo stuff to keep my factory radio, CD Changer, etc.
Extra door moldings used.
Probably a lot I am forgetting.
The rest of RCP Phx's list is pretty much what I am also working towards.
Especially the heater core and oil filter adapter and bolt
" Use before 2047 "
Those were all my hard parts
Spare PCM's
a couple throttle body's with OEM sensors
OHC
main PCM to engine wire harness
2x driver door wire harness
climate control panel
That reminds me.
Couple steering columns with the steering wheels and air bags.
Extra cruise control parts too.
I do need a back up cruise control clockspring though.
Extra climate control panel too.
Have the wiring harness and a couple PCM's for a Federal Emissions '00.
I own a CA Emissions '00. Wink, wink.
About 8 power seat bases in various condition.
Maybe 5 driver and 3 passenger.
Oh and the rear hatch window molding for a '97 and up.
Brand new in an opened package.
You wouldn't believe how long it took me to find that.
I just hoard 2 door side glass
