no heat?
Lavacrawler
Well my water pump went out last week so I replaced it and the thermostat (195*) all went together just great and the pump seems to work fine, but for some reason the heater doesn't blow as hot, not even close to what it used to. The engine reaches norm operating temps and everything. If I switch it to recirculate the inside air it will start blowing alot hotter but as soon as I switch to defrost or any other setting it goes back to luke warm.
So is there a sensor or something I screwed up when I replaced the pump and thermo?
Any help it greatly appreciated, it's been below zero and sometimes barely above around here and the heater is well needed.
Thanks
Cory
