Old March 9th, 2005, 15:42
jdraylob2002 jdraylob2002 is offline
2000 Fuel Filter
After buying my XJ last fall, i was amazed to not be able to find a filter on it. In doing some research, i see that the filter is part of the pump in the in the tank. Which i don't really like.
Has anyone been splicing the fuel line and putting in a filter anyway?
Old March 9th, 2005, 17:09
willyb's Avatar
willyb willyb is offline
Re: 2000 Fuel Filter
If you search I'm sure you'll find some information on it (I remember seeing it somewhere). But even if you put another filter on it, it will only add protection to the injectors/rail... I'd be a nice peace of mind, but the only thing that it would be filtering is what doesn't get past the stocker... Let us know if you do it though....
Will.
Old March 13th, 2005, 20:18
I just have a hell of a time believing that the filter inside the tank, with a life expectancy of 100k miles or whatever you'd like to compare it too, is worth a damn if it isn't regularly serviceable. I'm sure all things being considered.. the engineers know what they are doing, but when i'm used to replacing fuel filters every 15k miles, i start to wonder what might be accumulating in places it shouldn't.
I'll probably do some added research on the topic. If i do anything, i'll be sure to post about it. Thanks for the reply.
Old March 13th, 2005, 21:18
willyb's Avatar
The reasoning behind the 'lifetime' fuel filter/pump is from the accountants - Lots of manufacture's are doing this now. Let's see how many lifetime components I can come up with - just off the top of my head.
*Fuel Filter
*Spark Plugs
*Coolant
*Air Filter
And the list go's on.... I don't like the idea of not haveing a serviceable fuel filter either - but such is life...
IIRC there was a article floating around on JeepForum.com about replacing the inner component's of the pump/filter - ended up being a lot less expensive....
Will.
Old March 24th, 2005, 12:10
bajacalal bajacalal is offline
I'm really disturbed by this trend also. If I had one of these vehicles I would consider replacing the tank filter with an older style screen pickup if possible combined with a real fuel filter. Why? I drive a lot in Baja and other remote areas and sometimes the gas has a lot of dirt in it. I have plugged the filter only 2000 miles after changing it.
Old March 24th, 2005, 12:15
coderedxj's Avatar
coderedxj coderedxj is offline
Is this the same in the 99 XJ's? I'd like to replace mine too!
Old March 24th, 2005, 13:04
Don't quote me.. But i believe that its a 97 + trait..
Old March 24th, 2005, 13:40
rumblebelly's Avatar
rumblebelly rumblebelly is offline
Well, has anyone had any problems with them yet? So they've been using these filter for what, 8 years? I'm really not too worried about it.
Old March 24th, 2005, 15:00
willyb's Avatar
Yes, '97 up was when they went to the in tank version... Mine was replaced @ 110K - and I assume it'll need to be done by 200K as well... Many manufactures are going this route - it gets stuff out of the way - for other stuff. GM is an exception, most fords have an external filter as well...
Fuel Pump Relay Haywire? secutores OEM Tech Discussion 11 September 17th, 2009 00:31
Fuel cell in a 2000 XJ & Check Engine light edeslaur Modified Tech Discussion 0 October 6th, 2003 10:27
Fuel Filter aplatz OEM Tech Discussion 14 September 27th, 2003 05:41
leaking fuel filter?! CaptTrev OEM Tech Discussion 6 September 10th, 2003 16:54
Gas Gauge one 1999 XJ Manuel OEM Tech Discussion 4 April 15th, 2003 16:15
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
