Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Do the STP Fuel Injection Cleaner and STP Performance Booster additives work or help?
The title pretty much says it all. Just wondering if its all that its made-up to be. What about other companies that make the same products? I mean its pretty cheap ($2.00) for a bottle of either... so if it works or helps... I guess I could buy a bottle or two.
#2
i couldnt tell a difference, but i love my xj...so I dont mind spending 2 extra $ a month....
ps ghetto, youve got pm
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction* Last edited by hjeepxj; April 6th, 2003 at 12:57. |
#3
The cleaners work if you use them kind of on schedule. I add a large bottle of Chevron Techron about every oil change or so to keep the injectors clean. Once a year I borrow my neighbors 3M injector cleaning kit, pick up a can of cleaner/fuel and run that maintenance evolution. I also use Valvoline, the cleaner in the gold container if the techron is not on sale
#4
There is a company that makes an oil-additive called "Restore" in a silver can. After developing an erratic oil leak in my 66' mustang's 302 and running it out of oil twice (thank the Lord for Mobil 1! once I had about one quart left the other time I had just a little more, both times it was making noises it was so low!) I also developed a blue smoke out of one tail pipe and some degradation of power. So I thought, what the heck - can't hurt nothing too bad, eh? So I used it and lo and behold I gained power, smoothed out the idle and eliminated the blue smoke. I have no idea how many miles were on that engine, but the engine was pretty old and pretty hot so it couldn't have too many more years left. I sold it before it went criticial on me. my brother used it and said it certainly made a difference, but he didn't like it. I can't remember what it was exactly he didn't like, something like gas mileage problems or knocking or something like that. The stuff claims it restores compression. YMMV. Might be worth a shot if/when you have lots of miles on the engine. <shrug> Just a thought...
#5
i use restore in my oil too...
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction* |
#6
From what I understand Restore uses Teflon, which is why you need to "shake well before using". Dupont, the inventor of teflon, has said that it should in no way be used in internal combustion engines. I'll take what Dupont says over what some silver can says, IMHO.
#7
Top engine cleaner
Best stuff I have found is top engine cleaner from GM. They supposedly stopped making it, but I don't have any trouble getting it. I used to have a buddy that had a machine to do it, he dumped the can in and it ran it through the engine. Well, don't have access to it so I did what a gm tech told me to do. Pull the brake booster vac line and stick it in the can with the engine running. Keep giving it gas till the can is empty, then shut the engine off for 2o minutes or so. Then start it up and let the smoke bellow.
Dustin |
#8
Teflon AKA PTFE or polytetrafluoroethylene
I don't like the idea of putting it in my engine because it is a plastic. PTFE is used a lot on cooking ware which handles high heat but at the same time it probably doesn't reach the same temp as certain parts of an engine. Maybe I am wrong but PTFE is not something I think would work well in an engine. I have used several different products from top engine cleaner to oil system flush and injector cleaner. They have all worked. I have never tried the octane boosters or the NOS in a bottle additives. |
#9
The cleaners work, and most people reccomend them. I use a "total fuel system cleaner" every now and then.
As for the performance booster... ![]() The higher the octane, the more the fuel must be compressed/heated to explode. If your engine needs higher octane, it will "knock". The knocking is caused by the fuel exploding BEFORE the plug fires. So if it dosn't knock with strait up 87, anything else is just throwing money in the toilet. So go and buy two cans of the cleaner, and leave the additives for some other sucker. |
#10
My 2 cents only (Eurocents actually) Rgds |
#11
Re: Do the STP Fuel Injection Cleaner and STP Performance Booster additives work or help?
seafoam works great i use one third of the can down the throtlebodywhile its running and the rest in a full tank i pulled a injector once it was spotless
they say it can be used in the oil to clean the inside but i have never tried it though |
#12
wow old thread but a good one now gas has gone up
i use this stuff regularly - octane booster, fuel and carb, super concenrtated, lucas, restore (oil), and some others... i add it regularly to the gas - thats the key- i like my xj so whatever couple extra bucks no biggie |
#14
I just run Chevron fuel.. Have been for Along time.. works great..
Thread Tools | |
Display Modes | |
