WTB: wiring harness for 2000 XJ
altierior
i need the wiring harness that goes from the computer to the coil rail, the tps, etc...
and maybe the computer itself
(can anyone confirm or refute whether a 2001 will also work? this would increase my chances of finding something... )
I have a complete engine/trans harness out of a 2000 Xj. still hooked up to the engine. when I pulled it I just un hooked everything from the fire wall.
i only need the section that goes from the computer to the coil rail and sensors. i don't need ALL of the underhood wiring. i'm not sure what the correct name is for this particular harness, so i hope i'm explaining it clearly enough. i'm pretty sure it is removed simply by uncoupling about 15 connectors and snipping a ground wire.
do you have the computer? although i'm not sure that i need it.
how much would you want for this shipped to 19401?
yes i have 2 computers no i don't want to separate the harness
i will look in the strip yards around here and see if i can find you one ....
i think i've found what i need. thanks anyway. i'll let you know if this deal falls through.
