Old November 18th, 2005, 22:44
az4wheeler2002 az4wheeler2002 is offline
Question opinions needed
I've saved up acouple of bucks, whats everyones opinions on running a currie rockjock hp d60 in the rear and a d44 in the front? overkill?
I'll probably only ever run 33's
what about gearing, I'm currently at 4.56, would going to 4.88 also be overkill
Old November 18th, 2005, 22:46
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Re: opinions needed
What kind of wheeling?
ANwyways for 33's? Rear 44 and front 44 or rear 44 and a built up front 30. Gears? 4.88's. And I'll take 50% of what you just saved
Old November 18th, 2005, 23:00
88rockxj 88rockxj is offline
Re: opinions needed
you could break rockwells with 33s in the right situation , that being said go with a 8.8 in the rear and beef up your d30 and stay with 4.56s if youre only going to 33s.
Old November 18th, 2005, 23:01
Re: opinions needed
so you don't 4.88's isn't too low?
any idea if that will affect hwy speeds?
Old November 18th, 2005, 23:03
Re: opinions needed
regearing to 4.88s would be a giant waste of money if youre only going to run 33s, the only reason you should be thinking about it is if you have a 4cyl
Re: opinions needed
4.88's aren't too low, any idea if it will hwy speeds
Old November 19th, 2005, 07:43
Kejtar's Avatar
PostMaster General
Re: opinions needed
I run 4.88's in my jeep and I can do 80mph without any problems. The RPM's at 80 are about 3K which is just fine with the 4.0
Old November 19th, 2005, 07:44
Kejtar's Avatar
PostMaster General
Re: opinions needed
ummm and you're basing your opinon on...?
Old November 19th, 2005, 08:34
jonboy's Avatar
jonboy jonboy is offline
Re: opinions needed
..hp60. overkill?...I'll probably only ever run 33's
what about gearing, I'm currently at 4.56, would going to 4.88 also be overkill.
If you have to ask us, it's probably overkill. If you're only gonna run 33's, it's definitely overkill.
Going from 4.56 to 4.88's is not overkill, just a waste of money.
Unless you plan on huge tires, a better way to spend that excess cash is:
- Good rear 44 or 9 inch with alloy shafts and disc brakes
- Alloy shafts for the d30
If you still have leftover cash, please send it my way
Old November 19th, 2005, 09:05
Mr.OverKill's Avatar
Mr.OverKill Mr.OverKill is offline
Re: opinions needed
where is crashes gearing thread????
Old November 19th, 2005, 09:16
jrsxj98's Avatar
jrsxj98 jrsxj98 is offline
DILIGAF
Re: opinions needed
Really can you tell my WHY I WASTED MY MONEY..Cause I love my 4.88's
Old November 19th, 2005, 13:01
Re: opinions needed
try paying attention
you have 35s
hes only gonna run 33s
he already has 4.56 gears
if you spend 400$+ to go from 4.56 to 4.88 for 33 inch tires you are waisting your money unless you are VERY wealthy
are you drunk or somthing? he stated hes only gonna go to 33s and already has 4.56 gears, if you think hes not waisting his money going to 4.88s under those circumstances then perhaps you should buy them for him.
Old November 19th, 2005, 13:03
Re: opinions needed
im basing my opinion on the fact that he would be waisting his money regearing to 4.88s when he has 4.56s and thats the proper gears to run with 33" tires and a 6 cyl.
Old November 19th, 2005, 13:17
Gil BullyKatz's Avatar
Gil BullyKatz Gil BullyKatz is offline
Re: opinions needed
Wasting money?
4.56 vs 4.88?
33" vs 35"?
Wasting bandwidth...?
Guilty...
All of You!
Paying members forgiven...
The rest of you: JU beckons
Have a nice complacent day
Old November 19th, 2005, 13:27
jrsxj98's Avatar
DILIGAF
Re: opinions needed
you have 35s
So its your opinion so it is gosspil...Take yourself to JU
opinions needed on this coil outlander OEM Tech Discussion 4 November 16th, 2005 08:16
Daily driver drivetrain opinions needed... "Wolz" Modified Tech Discussion 29 February 14th, 2005 10:07
Q's about 8.8, opinions needed lisdexic Modified Tech Discussion 1 January 11th, 2005 18:38
Opinions on trail runs needed old_man XJ Fest 2004: Colorado 5 July 26th, 2004 20:24
quick disco opinions Mojo Troll Modified Tech Discussion 16 December 8th, 2003 20:36
