Sluder
- North Carolina
I've installed a 4in IRO lift on my 99 XJ. No problem!
A week later, I installed a 6.5in IRO critical path long arm lift on my 01 XJ and the front is sitting about 3 inches lower than the Rear.
I put a level on the XJ before and after lift install. Level before but now I have to jack up the front about 3 inches to get it level. Front coils for 6.5 lift measure about 21.5 to 21.75 inches without load.
Just curious if anyone has any idea what may be causing this? Haven't got anything solid from IRO yet.
1. I have driven it around to allow for settle.
2. I have adjusted caster adjustment to proper and varying adjustments tobsee if this will fix. Nope
3. 23.5 in between fender and hub center with lift installed and while sitting on ground.
Mike Sluder
Mike Sluder
