Transmission Cooler Radiator Quick Disconnect DIY EASY!
epitaphmike
Phoenix, AZ
I read a bunch of posts at 3:30 a.m. this morning when I decided to put in my new radiator before work. No one had any good solutions for not having the Quick Disconnect Tool. After some thinking, I cut about an inch and a half off of an extra hose clamp I had. I bent it around the tube coming off of the radiator, then i slid it into the quick disconnect and used a pair of vice grips to push it in and hold it. If the radiator is junk I recommend cutting the tube coming off of the radiator, it makes it easier to get to.
Hopefully this helps someone down the road.
98 Jeep Cherokee 4WD 4.0L
