Old May 18th, 2004, 23:32
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
Front Shock Relocation
I'm doing a full width 44 with custom bracketry and RE style radius arms. The way it worked out, my shock comes down right on top of the axle-side upper control arm bracket with no more room for compression (SEE PIC). I'm thinking of running a shock hoop to relocate the shock directly to the outside of the coil. I'll have up to 22" to work with vertically, but I was wondering what the downsides might be to running a shock that far out on the axle. I think it would have to be somewhat soft to compensate for the leverage. I'm running full width and insane backspacing to clear my brakes, so it doesn't look like the tire will hit anything at stuff. Anybody have any input? Or has anybody done something similar?
Thanks,
Billy
Old May 19th, 2004, 00:24
Rob Patterson Rob Patterson is offline
Re: Front Shock Relocation
I'm not an expert but having the shock outboard should provide better dampning and stability. You have the leverage thing reversed. Try and hold a 10lb sledge hammer with one hand at the end of the handle, now try to hold it right next to the head. The shock will provide better control the closer it is to the wheels.
A possible alternate shock mount would be to move your shock out just enough to use the existing control arm bolt location as the shock mount also. I did this a long time ago to mount 9012's in the front with only 4.5" of lift. I cut out the old lower shock mount and used a longer lower control arm bolt and washers to mount the lower end of the shock.
Old May 19th, 2004, 00:33
MockKnight's Avatar
MockKnight MockKnight is offline
What About moving the shock back a lil and mounting it to the radius arm. I have friend who is running a set up like that and he has no complaints about it. I think I have seen one or two guys on pirate running it like that too.
Just my .02
Sean
Old May 19th, 2004, 00:59
Goatman's Avatar
Goatman Goatman is offline
No negatives at all to running the shock further out, and like has been already said, it's more of a positive. You're already welding up custom brackets and mounts, just put the shock where ever you want it. Cycle the suspension, for both full droop and stuff, and for articulation, with no springs in it, and figure out where the best location is for the shock to not bottom out and to clear everything.....then build your mounts.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old May 19th, 2004, 07:45
Just my .02
Sean
That's how I had it in long arms version 1.2 beta Worked great, but it's not going to work in version 2.0... just don't have the room.
Thanks,
Billy
Old May 19th, 2004, 08:29
rockwerks's Avatar
rockwerks rockwerks is offline
Actually loss of wheel travel would be the negative the farther inboard the shock the more the travel for same length shock.
what about angling the shock base forward a bit and building a bracket that would attach to the upper arm mount. Several degrees forward would give you some antidive which would not be a bad thing on a high lifted cherokee
WTB front dana 30 diff guard for 90 xj in CA lapaul Wanted: Private Party Only 2 December 11th, 2003 14:27
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 15:04
Weird popping sounds up front Fonzie14 Modified Tech Discussion 3 December 9th, 2003 14:43
Shock hoops BobCSmith Modified Tech Discussion 6 December 6th, 2003 14:21
Why is front shock contacting frame? giranger Modified Tech Discussion 4 May 9th, 2003 17:36
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
