Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
  #31
Old February 18th, 2012, 20:55
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
Re: common tools for the trail??
Originally Posted by ROBZ95Xj View Post
i dont see why peaple take the 36mm socket for the axle nut, just have a hub already installed on the shaft then you will just need a 1/2 or 13mm 12pt socket
I run the RCV's so i'll never blow a shaft but I have ripped a ring gear apart so when that happens I have to remove the RCV's, install/torque stubbies and plug the axle tubes in order to get home(plus pull the front DS)
Yes my Heep is heavy but i have used about every tool or spare part on that list on the trail or in camp on my rig or others.
If I didn't carry something with me, that would be the one thing i need!
Old February 18th, 2012, 21:23
kastein's Avatar
kastein kastein is offline
I generally take mine because I just sling the whole toolbag into the jeep, easier to not forget anything. Hell, I even bring my external torx
I'm glad I did, I ended up blowing a radiator hose due to a stuck thermostat at Fall Crawl and it would have been a real pain in the ass to change the thermostat out if I hadn't had my gasket scraper with me. Who the hell brings a gasket scraper with them while wheeling? I didn't, at least not intentionally.
... and I carry spare rad hoses, hose clamps, and a thermostat and gasket now too.
My yard looks like Sanford & Sons.
Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old February 19th, 2012, 08:58
Ben H's Avatar
Ben H Ben H is offline
Air
Welder, with a grip of rods
Full set wrenches/sockets
Scanner
Hammer
Grinder
Any specialty tools (hub socket, fuel line discos ect.)
Bailing wire
Duct tape
Spare critical sensors
Spare tranny/steering fluid
Spare steering joints
Spare Ujoints for drive shafts
Everything else can wait until you get home.
Old April 25th, 2012, 06:34
rtralabama rtralabama is offline
i carry a husky mechanic tool tray with a bunch of sockets. a cooler chest filled with a hammer, rubber mallet, pipe wrench, shop towels, bleeder kit, screw drivers and others things. i then have crates with straps, ratchet straps, oil, napa filter, power steering fluid, coolant, ATF and gear oil. last thing i have is a good ole' hi-lift jack. i also have a tent in there in case things dont turn out too well or we find a nice spot to stop at.
Old September 9th, 2018, 01:36
ericsennert's Avatar
ericsennert ericsennert is offline
I'm glad I found this post. This is good info for the "Moab newbie" such as myself.
I know just enough to be dangerous.
Old April 15th, 2020, 04:50
joey_rider joey_rider is offline
which are 6 pt and 12 pt. sockets ? Thanks.
Old September 26th, 2020, 03:59
Vince's Avatar
Vince Vince is offline
Most of my sockets and combination spanners are 6 pt. The 13mm 12pt being one that I will stash a spare of in the glove box or in the centre console as they always seem to go missing from my tool bag.
I have been using Metrinch tools since the early 1980's. They work on both metric and inch sizes (In the UK it's metric and imperial). In some sizes, one Metrinch socket can replace four conventional sockets. Which is great for reducing weight and storage bulk.
I am on my third set now, having lost the previous two sets in cars that were stolen from me. https://metrinch.tv/collections/metr...nch-socket-set
As much as I love my Metrinch tools, they are not ideal for every situation. I still need wrenches for sizes smaller than 10mm. Just yesterday I purchased a 6pt 8mm full hex brake spanner that saved me a lot of grief after my 12pt 5/16" ring rounded a bolt on my transfer case front yoke.
Old February 27th, 2021, 02:01
StephenShort's Avatar
StephenShort StephenShort is offline
thx for sharing
i also use cardboard and works great
Rate This Thread:
Trail Tools Phil Non-Tech / Off Topic 45 November 12th, 2008 16:43
Let's Talk Trail Tools TheAlmightySam Non-Tech / Off Topic 22 November 10th, 2007 04:33
trail tools Sting25 OEM Tech Discussion 33 July 3rd, 2007 19:48
Trail Work: What tools? bburge SoCal Chapter 7 April 18th, 2005 10:09
Trail Tools? What to Carry? minerjeepguy Modified Tech Discussion 32 September 26th, 2004 16:43
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
