Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
  #31
Old November 19th, 2021, 20:03
Anak's Avatar
Anak Anak is offline
Stranger
Re: Dr. Dirt is in surgery
Sure looks cool.
What is the reason for the serpentine belt? I don't recall ever having belt issues with a bug, but then again I was never trying to push the design envelope with them either. Is there a limitation on the V-belt that comes into play? Or is it just that the serpentine setup is one more way to trick out a bug?
Old November 19th, 2021, 20:18
RCP Phx RCP Phx is offline
V-belts have always been a issue with high HP/high RPM motors and the VW's system sucks when dealing with them. Now it's a snap to change a belt in what is a much better system overall.
Old November 20th, 2021, 08:15
I learned my lesson 50yrs ago on a surfing trip to San Diego. We just hit the summit at Pine Valley when the gen light came on, you've got about a minute to pull over to a stop. It was nightime so we had to let the motor cool down and basically had to coast all the way into San Diego and p/u a belt the next morning!
Old November 24th, 2021, 07:53
Plans change fast, now I'm going to build a new motor changing from 1955cc to a 2110cc. That will put my new rockers and the new cam to work!
Old November 24th, 2021, 13:23
Anak's Avatar
Stranger
Grenaded it huh?
Old December 16th, 2021, 12:47
The old motor (500-1000 miles) looked so good I will probably just build it back as spare motor. Although I have built 100's of these using the old factory magnesium cases this will be a first with a new aluminum case (about 20lbs heavier). The rest are Mahle forged pistons and a forged 82mm stroker crank with H-beam rods.
Old December 16th, 2021, 14:33
Anak's Avatar
Stranger
What advantage does the aluminum have?
Old December 16th, 2021, 15:11
Strength, part of the reason it's so heavy is because it has material where there was none before!
Old December 20th, 2021, 16:56
I got the case prepped and painted this weekend!
Old January 5th, 2022, 11:03
I'm back on top of this after a major set-back. I assembled the bottom end on Christmas eave only to find out the crankshaft locked up and had to tear it back down on Christmas day! Long story short after all the shops were closed thru New Years I'm back going again!
Old January 23rd, 2022, 11:43
Try again after everybody in my house got Covid! I finally got the entire engine assembled, now I have have to measure for pushrods and order up some custom ones.
Old January 23rd, 2022, 12:20
maxbraketorque maxbraketorque is online now
Your work is awesome.
Old January 23rd, 2022, 12:41
jeep ride's Avatar
jeep ride jeep ride is offline
Your attention to detail is second to none.
Old January 23rd, 2022, 13:33
It's where I started my first business 40yrs ago and still my first "love". Between fitting parts, masking, painting, polishing aluminum and stainless it's still a labor of love as all motors are to me!
Old January 23rd, 2022, 15:15
I got the "big bore" pushrod tubes and valve covers installed.
Rate This Thread:
Going for surgery in 3....2........1 flingshot Colorado Chapter 58 June 14th, 2011 08:05
Nicks surgery! RedJeep2.0 NorthWest Chapter 9 April 2nd, 2011 23:45
surgery 1xfloppy SoCal Chapter 28 October 13th, 2007 22:23
Leg Surgery, how's it after? LilRhodyXJ Non-Tech / Off Topic 15 January 30th, 2007 08:15
1990 XJ in SOCAL 4x4 4.0L 128K miles DIRT DIRT CHEAP. Kal For Sale: Private Party Only. XJ ITEMS ONLY 6 September 21st, 2006 11:27
