Old January 30th, 2017, 20:03
GreatOdin'sRaven GreatOdin'sRaven is offline
Gas pedal vibrates when Jeep decelerates. Wtf.
The Jeep also makes a clicking sound like it's coming from behind my dash on drivers side.
The sound increases in frequency as the car increases in speed (not the engine RPMs)
Clicking sound/vibrating gas pedal occurs when Jeep is at steady speed, and loudest when decelerating, never when it's accelereting.
Any thoughts? Looked over engine bay, all looks normal.
Old January 30th, 2017, 20:37
trippled trippled is offline
Re: Gas pedal vibrates when Jeep decelerates. Wtf.
Checked the u joints lately? And CV portion of front shaft?
Old January 30th, 2017, 21:04
md21722 md21722 is offline
Remove front and rear driveshafts alternately to help isolate the problem. Could be driveshaft u-joints or pinion bearings.
Old January 30th, 2017, 21:42
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Take a flashlight and look at the front driveshaft U-joints.
If you see one with rusty red dust around it, that's the
bad one.
Old January 31st, 2017, 13:23
Thanks guys!
I just bought this Jeep and it was like the 3rd time I've driven it after I had made a lot of repairs.
I installed an after market bumper and this happened on the first drive after that. I do not think they were related.
Will inspect u joints tonight.
Old January 31st, 2017, 17:48
Other than being rusted to hell, they seem fine.
I'm gonna remove the shafts one at a time as previously mentioned to isolate the issue.
Old February 1st, 2017, 12:44
I've seen a lot of seized u joints with little to no external sign. Only way to know for sure is to remove the shaft and feel each one.
Old February 2nd, 2017, 14:34
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
What year is it? 2020? LOL
OK, the behind the dash clicking sounds (LOL) like the speedometer cable-odometer package, the gauge or the cable, on an older style XJ like Renix era....
The vibrating pedal, is during breaking? You said during deceleration, but since it is the brake pedal, I assume you are applying the brakes too, foot on the pedal otherwise you would not fell the vibration, is this correct?
If yes, it maybe notches, groves in the slide area on the knuckle where the brake pads ride. A good skilled welder can repair them. The pads get stick there and when the caliper engages it jumps around, pulsing the pedal. It could be an out round brake rotor too.
http://i263.photobucket.com/albums/i...3/IMG_2214.jpg
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old February 2nd, 2017, 14:36
Ecomike's Avatar
NAXJA# 2091
I think this link is a write up on repair them
http://www.jeepforum.com/forum/f9/xj...rooves-924713/
Old February 2nd, 2017, 14:40
Ecomike's Avatar
NAXJA# 2091
Good luck removing those axles, your gonna need it with that kind of rust. Three star head bolts on the knuckle (IIRC) are a bitch to remove on a clean rust free rig, takes an impact socket and using the jeeps hydraulic steering power to bust them loose (I forget the exact details, but it was trip the one time I did it), before you can even start on that rust mess.
Whole Jeep vibrates like a subwoofer only when in gear 970xjsport Modified Tech Discussion 2 August 17th, 2016 12:04
Brake pedal drops when I start the Jeep md21722 OEM Tech Discussion 11 April 8th, 2016 00:37
1993 jeep xj vibrates 1993jeep OEM Tech Discussion 2 January 31st, 2012 03:33
Elec fan vibrates jeep... 4byfour OEM Tech Discussion 10 July 28th, 2008 11:18
93 XJ AW-4 Vibrates in reverse newjeep OEM Tech Discussion 1 July 22nd, 2005 22:26
