Old March 7th, 2008, 06:51
obx-xj's Avatar
obx-xj obx-xj is offline
Sludge
Alright so I was getting ready to do an oil change last night and when I crawled under the jeep it appears as if everything is seeping. There was a little seepage from both differentials also the transmission and transfer case. It seemed that down the center of my Jeep oill was be srayed back as I was driving. It's an '01 with 4.5" of lift running 31's. I don't know if that helps at all but...Any ideas of what might be going on would be appreciated.
Old March 7th, 2008, 07:05
87manche's Avatar
87manche 87manche is offline
Re: Sludge
degrease the whole thing, then start looking for leaks.
back of the valv cover is common, as is some seepage from the oil filter adapter.
if you've got rubber plugs in the diff's then that's a common leak too.
Old March 7th, 2008, 07:06
4LowandGo's Avatar
4LowandGo 4LowandGo is offline
Re: Sludge
Maybe start by checking your fluid levels and then prioritize the leaks from there.
Old March 7th, 2008, 07:30
obx-xj's Avatar
Re: Sludge
I checked the fluid levels last night and they seemed fine. I just hope it nothing major or incredibly expensive. The differnetial I am not to concerned about because I am getting ready to regear. I also notice on the engeinge cover there appeared to be a little wet as well. Nothing major but just part of the cover looked wet.
Old March 7th, 2008, 07:33
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: Sludge
It's a Jeep. Jeeps leak.
Seriously, after a certain amount of time, various things will seep, and unless you're seeing puddles, I'd relax about it. Check engine gaskets, etc., and make sure the oil filter adapter is not leaking, and make sure there is no big leakage from the tailshaft of the transfer case, and then chill. It can take years of that kind of leakage before any fluid levels go down enough to worry about.
Old March 7th, 2008, 07:49
obx-xj's Avatar
Re: Sludge
Ok thanks I feel a little bit better now. I guess I will just go ahead and move ahead with my oil change and tune up.
Old March 7th, 2008, 07:57
garr garr is offline
Re: Sludge
The oil filter adapter is usually the biggest culprit, read this http://www.madxj.com/MADXJ/technical...Conversion.htm before you attempt the repair, Purchase the O ring kit from jeep (It cost less than $5) The repair took me 30Minutes once I rigged up a wrench to get the T-60 torx head bolt out.
I used a short 3/8 drive T-60 (From autozone) on a 3/8 breaker bar & a 3 foot lenght of heavy 1" pipe to break the Torx bolt loose.
good luck
Old March 7th, 2008, 11:14
Jess Jess is offline
Re: Sludge
just carry extra fluids and check often.
oil sludge bj-666 Tow Rigs and Trailers 0 August 18th, 2007 23:34
Mmmm...Sludge wraithblade OEM Tech Discussion 23 March 15th, 2006 05:20
Sludge build up slowrider OEM Tech Discussion 15 July 25th, 2005 12:34
CCV and Intake sludge Boonie Rat OEM Tech Discussion 4 May 19th, 2004 08:27
AW4 tranny sludge JohnJohn OEM Tech Discussion 9 March 15th, 2004 09:44
