JeepCherokeeGuy99
- New Bern, NC
Well after having vibes on the freeway I looked at my rear driveshaft (front shaft off a 95 zj v8) and noticed this:
1. I was missing a bolt attaching the shaft to the SYE yoke
2. All other bolts were hand loose
3. One of my caps fell out.
This is what it looks like on the centering ball. I believe I'm going to need a new one, as you can see in the top right of the yoke, its been ground off a bit.
I've spent the last two hours looking for that damn part on ebay, autozone, google, etc. Anyone have a part number for it and or a link to where I can purchase it from?
Also, the yoke at the transfer case was ground off very mildly. Does it look like I should get a new yoke there too? If not, will the new U-joint im going to be putting in be affected by this?
look at the bottom left hole. Missing a little bit of metal.
