Old April 7th, 2004, 19:35
prljeep's Avatar
prljeep prljeep is offline
Gas Tank and Skid Plate
Anyone have problems removing the three rear bolts of the gas tank skid plate? I had to cut mine off. If so, how did you all fix the problem?
Anyone have a problem with their gas tank rusting out on the frame rail side, directly below where the gas goes in? It looks like I had road salt and grime build up in that area and cause a leak. Can I cover my new or repaired tank bedliner or rubberized undercoating?
Thanks!
Old April 8th, 2004, 06:13
RichP's Avatar
RichP RichP is offline
Re: Gas Tank and Skid Plate
Ahhh, the advantages of using anti-seize... After you get it all apart reassemble with anti-seize, clean the whole area up with a grinder/sander/growler, reprime it and repaint it then undercoat it. You could find an old innertube and cut it up to act as a gasket between the skid and the frame, thats what we did with the YJ as needed, quiets things down some and acts as a barrier between the steels so that you don't get any rust again..
Old April 8th, 2004, 07:47
prljeep's Avatar
Thanks for the idea! Someone send the anti sieze formula to jeep engineers- maybe they will get the hint!
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
