Old January 2nd, 2009, 22:03
XJRocket XJRocket is offline
Late dash into early XJ...I did search.
I searched and found that the late dash into the early body is a cluster, if you don't have the wiring harness and ecu etc out of the late XJ. Aside from the gauges, how hard is it? I was just thinking of using some autometers since the factory gauges are craptastic anyway.
Old January 3rd, 2009, 07:50
Jeepm@n Jeepm@n is offline
Re: Late dash into early XJ...I did search.
Check this thread out. It shows how the newer dash fit into a MJ. The Mj would be similar to the older style Cherokee.
http://www.naxja.org/forum/showthread.php?t=979009
Iowa Meet and Greet Part Deux-late Nov. early Dec. BIGSLVRXJ Midwest Chapter 109 December 1st, 2008 19:28
Difference in body sides between early and late model??? WheelinJR OEM Tech Discussion 5 July 2nd, 2008 20:59
wnated early 90's late 80's xj rwallace Wanted: Private Party Only 1 January 7th, 2007 16:34
Seat interchangability for early/late models AJPulley OEM Tech Discussion 1 May 22nd, 2006 19:48
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 13:48
