KellyBuilt
- Oklahoma
Hey there, so I just got a non running 1990 Jeep XJ. Previous owner said it ran good then quit and acted like it was out of time when he went to turn it over. I brought it home, put a new battery in it and sure enough it sounds like it out of time. He thought maybe the timing chain had broke, I did alot of research and cleaned all the grounds I could find, installed a new starter and cleaned up the cap and rotor and installed new plugs and its still doing the same thing. Today I decided to pull the distributor and where the bottom of the distributor goes into the oil pump is broken I believe. Does the motor need rebuilt or can I just put a new oil pump in?
Picture I found.
https://i.imgur.com/6HHHSJp.jpg
What mine looks like, I can move the pin all around
https://i.imgur.com/A7YWI47.jpg
Picture I found.
