Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter > SoCal Chapter Adopt-A-Trail (AAT)
SoCal Chapter Adopt-A-Trail (AAT) A forum for the discussion of the SoCal Adopt-A-Trail Program
Old June 7th, 2019, 11:54
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
June 22nd, 23rd 2019 Workday(s)
UPDATED.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter President
Old June 17th, 2019, 09:28
peterjford peterjford is offline
Re: June 22nd, 23rd 2019 Workday(s)
What are the chances someone would notice my expired (2 years ago) registration? I need to get all the monitors cleared in the OBDII and the last time I had to do that a trip to Johnston Valley did the trick. If the monitors are cleared before that I will be getting it smogged so I can go without fear in July.
Peter J. Ford
Purple Is The New Chrome
KK6QQV
Old June 18th, 2019, 20:14
Bent's Avatar
2N49 Saturday morning at 9:30 AM. Trailhead is at the East end of Palm Avenue in San Bernardino. Exit I215 at Palm Avenue.
It is rattlesnake season so bring reach extenders if you have them. Boots and a hat are good.Also bring food and hydration. It will likely be on the warm side.
We will be looking for any trees that are down, or partially down that need to be removed from the trail, trash removal and assessment of any illegal trails and what it will take to block them.
If anybody is planning on camping Saturday night please let me know in advance. Camping will either be on the trail or North Shore work center in Arrowhead. No wood fires on the trail; only at North Shore.
Old June 18th, 2019, 20:16
Bent's Avatar
Peter, if you have a paid receipt for your incomplete registration sometimes they will let you slide when you explain the whole computer reset to them. Other than the freeway we won't be on any paved roads frequented by CHP.
Disclaimer: this is not an endorsement.
Old June 19th, 2019, 16:28
Carol.92124's Avatar
Carol.92124 Carol.92124 is offline
Yes, it's MY Jeep =)
Peter, if you're a AAA member, you can go get a free one-day moving pass from them rather than going to the DMV... Or if you have a local friend who does...sometimes they will even give you a blank one for you to fill out the day you plan to move it... or when the lights go on in your rear view mirror
My concern is that if the police DON'T let you slide, they can tow your rig on the spot... especially anything over 6mos old. And the purple trim, no matter how faded, might be an eye-catcher.
I'll probably miss this one again, I have plans to camp on Elephant Spur sometime between 6/29 & 7/3. Picked up random trash en route when we camped up there over Memorial Day, I should submit those hours I suppose.
GrimmJeeper "The rule of buying things is if you have to ask yourself if it's a good idea or not, it's probably not."
White 98 2Door named "Cali", 4.56s, rear D44 w/Aussie, 31" M/Ts, AJ's SuperRails Rockrails, Custom 4x4 Fab towhooks, JKS discos, 3" "pretested" lift so far--Hey, I'm still working on it!
SoCal Chapter Treasurer
Old June 19th, 2019, 19:04
Bent's Avatar
Carol, yes on the hours.
Peter, she makes some valid points. I forgot about impound.
Old June 20th, 2019, 12:26
Originally Posted by Carol.92124 View Post
...you can go get a free one-day moving pass...sometimes they will even give you a blank one for you to fill out the day you plan to move it...
Went to the DMV and got 3, just don't want to have to use them up before its smogged.
Peter J. Ford
KK6QQV
Old June 20th, 2019, 12:30
Anak's Avatar
Anak Anak is offline
Stranger
Do they no longer do month-long temporary operating permits?
Baby it's cold outside.
Old June 20th, 2019, 13:09
Bent's Avatar
It depends, if he's let his registration lapse then there's no way in h*** he's going to get one.
Otherwise he's limited to one day only, and that's if he has paid all his fees or back fees. If you are really nice and explain the smog and computer/ sensor situation they will sometimes give you two or maybe three if you're lucky at one time.
If you tell them that you have to drive it to the mechanic and leave it at least overnight. Then after you pick it up you have to drive it around for a 100 miles or so, and then the following day take it back to the mechanic to get smoged, that will get you three.
Old June 20th, 2019, 14:44
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
If only we knew someone with a DRB III that can help walk your jeep through it's drive cycles...
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old June 20th, 2019, 18:19
Bent's Avatar
If only.
Old June 21st, 2019, 13:22
I have a list of the things it wants me to do, but some of them are hard, like drive 45mph for x minutes, and of course 20 seconds before you reach x minutes you hit a red light.
Peter J. Ford
KK6QQV
Old June 21st, 2019, 17:22
Coffee Drinker
Drive on the freeway nice and slow in the right lane, when the time is up, pull over, let it idle, then repeat. It helps when you have the DRB because you can see the parameters it's looking for and the timers that you can watch count down.
Old June 22nd, 2019, 09:54
Bent's Avatar
I'm running about 15 minutes late.
Old June 22nd, 2019, 10:25
chasdb's Avatar
chasdb chasdb is offline
NAXJA Member 3643
I started up the trail will head back to trailhead.
'00XJ Mall Krawler Edition Russ Pottenger 4.7Stroker,241OR, Rock Krawler aluminum 3 link, D44hp Yukon air zip, D44 35 spline axles locked by RWKHaus. Stiffners, and brackets by Ruffstuff. High steer-Parts Mike. T&J, fenders+ cage. Bilstein 7100, 35 KM2, OMF Beadlocks, PAC coils, Deaver G9leafs, BrownDog mounts, Currie antirock, PSC hydro
my build
Rate This Thread:
Adopt-A-Trail Workday - April 22nd peterjford SoCal Chapter Adopt-A-Trail (AAT) 24 May 3rd, 2017 22:33
Windrock weekend trip august 22nd and 23rd. shortxjdoug South East Chapter 24 August 20th, 2009 12:06
Bruin PA. july 22nd/23rd outback adventure stevestiller Competition and Events Forum 1 June 27th, 2006 15:36
22nd-23rd So Cal NAXJA Chapter's Calico Run Kejtar SoCal Chapter 20 January 18th, 2005 19:58
Snow run. Nov. 22nd-23rd. WesternXJ Sierra Chapter 38 December 3rd, 2003 11:30
