Old September 13th, 2008, 00:54
markw's Avatar
markw markw is offline
web wheeler
XJ Dana 44 Ford Explorer Disc Conversion Howto
Ok, I've been doing some research on converting my XJ rear Dana 44 over to rear discs. Here's what I found during research and what made me go this route, it's unbelievably cheap and easy to do also. The other thing is that lots of guys use crown Vic backing plates/calipers, which are the same rotor as the Explorer, but the calipers face opposite directions. Plus once you have them facing the same way, you have to pull a caliper to bleed them. So anyway onto the Explorer stuff. I used brakes off a 95 explorer.
First were the measurements. I got these out of the 2008 Teraflex Catalog pages 91 and 92.
There are basically 2 patterns for the retaining plates/backing plates on the Jeep D44. The new style which matches the TJ and ZJ backing plates, and the old style which is closer to the Ford backing plates.
The new style Jeep backing plates aren't even close as evidenced by the shiny 03+ rubicon retainer plate next to the XJ D44 retainer plate. The rubicon plate is off both horizontally and vertically, yet most guys modify this plate for disc brakes.
I chose the Ford explorer rear discs for this conversion because of the spacing of the backing plate bolt holes. Very easy to modify the backing plate to fit with a die grinder, and here's why.
The 8.8" 95-01 Explorer rear disc backing plate has a 2" by 3 9/16" bolt pattern.
The 86-90 XJ D44 has a 2" by 3 11/32" pattern, which gives a horizontal difference of 7/32". So the holes in the explorer backing plates need to be elongated to the inside and it will bolt right up to the XJ housing.
Here's the XJ retainer plate over the explorer backing plate after elongating the holes with my die grinder. This is a stock XJ retainer plate.
Next problem, hat height. The TJ and XJ use the same rear D44 axle shafts, and the TJ has disc brakes on the rubicon. So, I looked up hat height for the two rotors. The Explorer rotor is a 2.275 height and the rubi has a 2.295 height for a difference of .020" which is fairly negligible considering the explorer caliper is floating over the disc. So this really isn't a problem.
Third problem is the center hole of the rotor, I'm lucky, I've got a neighbor whose an active gear head with a lathe. I think he said he removed about .015" from each rotor. It was fairly negligible, and could probably be done with a flapper wheel and a few minutes worth of work with a die grinder. I prefer the neighbor with the lathe resource though as that centers the hole. Or you can have a machine shop do it.
Here's the rotor installed on the axle shaft.
Fourth and final problem. How to make up the for the difference in thickness between the Explorer backing plate and the drum backing plate. First some dimensions of these two parts.
The Ford Explorer backing plate is .350" thick.
The drum backing plate is .125" thick for a difference of .225".
One meet and greet later, I had the answer. Mike aka Willy51 mentioned that Currie sold the Teraflex kits and they used a spacer. So a call to Teraflex had the answer. For $6.95 each, I got the spacers for the Teraflex kit. I ordered 4 spacers. The teraflex preload spacers are PN 86261 and you just need to call and ask for the preload spacers for the early jeep/dana 44 disc brake kit.
Here's the Teraflex preload spacer. Notice that it's tapered on one side, the tapered side goes towards the axle shaft seal. The spacers themselves are .226" thick, by 2.850" diameter and has a .250 wall diameter. It looks like it was turned from 2 7/8"x.250" DOM or chromoly tubing as I see no evidence of a seam.
Here's the spacer thickness compared to the Rubicon retainer plate.
And in diameter:
Finally with the backing plates modified they're test fit to the housing. One thing I did do was to drill out the bottom rivet that holds the dust shield in place so the retainer will fit flat. It's still shown in this picture, but has been removed for final assembly.
With that out of the way, it was time to press bearings onto the shafts. Here's how the stack went from inside to outside, or left to right in this picture. Bearing retainer, bearing, axle seal, preload spacer with taper towards seal, retainer plate.
Now to install the axle and bolt down the retainer plate. Here's a fun part that I think I'm going to fix with the welder. The preload spacer wants to drop down against the axle. There's plenty of room so I'll put a couple tack welds to hold it centered on the retainer plate.
Here's the disc installed before putting on the caliper.
Finally the caliper with brake pads.
This axle was just used to mock things up. The backing plates are coming back off and everything is getting cleaned up.
For brake lines, I'll be welding some 8mm x16mm bolts onto the housing, and using 2 explorer passenger side lines, and modifying or replacing the drum hard lines. I'll post more pictures as we finish routing the brake lines and install the other axle.
The cost breakdown for this conversion is:
$45 backing plates/calipers. Or if you get lucky like Tom did, they charge you $20.
About $200 at napa for rotors, brake pads, caliper kit, ebrake shoes.
If you're lazy, you can buy this kit from Teraflex or Currie for around 500 bucks and it doesn't come with the brake lines or ebrake cables, but it does use all new parts.
This still leaves the question of ebrake cables.
There are three ways to do this.
One: is to cut the spring off the stock cable, fold it over and use cable clamps and a thimble to keep the ebrake arm from cutting into it.
Two: Use the Lokar clevis kits and modify them for the drum cable end.
Three: Use the Lokar universal ebrake cable kit and build your own cables.
Four: Liberty cables... Thanks to the 8.8 ebrake thread and xjohnnyc PN 52128510AG. Also mentioned is grand cherokee cables. Check the length. I'm running 2 passenger side YJ cables with an extended rod on the ebrake handle.
Being the cheap bastard that I am, I'll probably opt for #2, but look seriously at #1.
So to sum up what's happened so far. 95-01 explorer brakes, elongate the mounting holes to the inside. Give neighbor a beer and have him machine the center of the explorer rotors to fit over D44 axle shafts. Get spacers from Tera, or machine your own. Use two passenger side explorer brake lines and weld a bolt to the axle housing to mount them, then rebend/redo hardlines into the explorer lines.
Oh for proportioning valves, I picked up a disc brake prop valve and will use the guts from it in my XJ valve. I've already got the dual booster master cylinder from a 95 XJ.
I'll post the brakeline pictures later this weekend or next week sometime.
Mark Wolfe
N7YMW 95 Sport, locked and lifted.
Lakeside, CA
Old September 13th, 2008, 01:55
poorboy_616's Avatar
poorboy_616 poorboy_616 is offline
Re: XJ Dana 44 Ford Explorer Disc Conversion
Dude, that's an awesome article!!
Old September 13th, 2008, 09:29
97Jeepers's Avatar
97Jeepers 97Jeepers is offline
Fantastic! Dammit, I already bought the D35 Zj parts for this mod, I might have to reconsider!
Old September 13th, 2008, 09:39
tkjeeper's Avatar
tkjeeper tkjeeper is offline
Very impressive! I'll follow your progress as I plan on regearing my d44 soon as well as rebuilding it etc. Good job, keep the pics and write ups coming, thanks and good work!
Old September 13th, 2008, 09:42
markw's Avatar
web wheeler
Yeah, after looking at bolt patterns, I was thinking, why the heck would anyone modify the D35 ZJ parts? I've searched high and low and didn't find anything about this, but heard it could be done so I figured I'd do it. I think I spent like 10 bucks on a 1/4" carbide bit for my die grinder to elongate the holes. Basically go 1/8" inside on each one and bolt the whole mess on. The axle in the picture has a 33 spline ARB and 4.88's. We still have to paint it and plumb it, then regear the front. Oh, the nice part is that axle isn't mine, someone else financed the test run.
Mark Wolfe
Lakeside, CA
Old September 13th, 2008, 16:49
Kittrell's Avatar
Kittrell Kittrell is offline
You can also buy Wilwood brakes, and Ebrake cables from M.O.R.E.
Old September 13th, 2008, 17:19
markw's Avatar
web wheeler
Cool, thanks. I'll probably go with modified lokar adapters, or get a thimble and some cable clamps. It's just an ebrake.
Oh, here's an update. Crown Vic brakes keep coming up. They use the same rotors, and the bolt pattern is the same. However, one caliper is leading and the other is trailing. (ie front/back of the rotor). Also, even though the bolt pattern matches, the center hole will need ground out. Same with the rotor. So it's hit/miss, I think the Explorers look nicer since they're both on the same side of the axle and it was less grinding to just elongate the bolt holes vs enlarging the center hole. But that's me, either will work.
Mark Wolfe
Lakeside, CA
Old September 13th, 2008, 20:15
stewie's Avatar
stewie stewie is offline
when i put ZJ brakes on my 8.25 i used KJ brake cables. they needed slight modification to work. the amount of cable that is exposed on the lever end of the cable was too little on the KJ cables to go on the bracket thats on the threaded rod and then clip onto the stock bracket. I pulled the clip bracket off of the outer sleeve, cut the outer layer to the same length from lever end as the stock XJ cables. then i cut the spring that wraps arround the cable to the same length as i trimmed the sleeve. i unwound the spring. then just press the forward clip bracket back onto the new end of the protective sleeve. then mounting the forward end of the cables is the same as stock.
hth with the cables
stewie
Old September 18th, 2008, 08:37
downhillracer downhillracer is offline
Thanks for your write up, I just pulled my explorer parts yesterday and ordered the spacers from teraflex. Ill snap some shots when i start to do my build. All parts total about 300 bucks with new calipers and rotors.
Old September 18th, 2008, 09:40
JAS's Avatar
JAS JAS is offline
Re: XJ Dana 44 Ford Explorer Disc Conversion Howto
markw Also a big thank-you
I have the parts in my garage from a Crown Vic.... I have had them for nearly a year. I was trying to figure out what I would do about that spacer I placed an order for the spacers yesterday with TeraFlex.
Thanks
Jeff
Old September 18th, 2008, 09:53
mjma's Avatar
mjma mjma is offline
Nice write up!! Wish I took that many pics when I was doing mine!
I used the crown vic backing plates, rotors, etc. and the rubicon retainer plates. Has worked great for over two years now!
Old September 18th, 2008, 11:12
hot_rod_hooligans's Avatar
hot_rod_hooligans hot_rod_hooligans is offline
Just got back from the JY with my '00 Explorer backing plates, going to go back Monday for the calipers(have to spread the parts out over time for the budget), I think I'll have about $160 in it, more if I decide to take the rotors to a machine shop. In all I think I'll have about $300 invested in my junk yard D44.
Before:
After:
Old September 18th, 2008, 11:21
markw's Avatar
web wheeler
I wish someone had taken pics. Did you have to open the center hole in the backing plate on the crown vic backing plates? I'm hearing you have to, but the bolt holes line up.
Mark Wolfe
Lakeside, CA
Old September 18th, 2008, 11:26
markw's Avatar
web wheeler
Looks purty. Did you regear? Here's a trick at pick-a-parts. Leave crap bolted together.
Ie. bezel and corner marker light, they charge you for the light. Tom took the calipers and backing plates up and they charged him like 20 bucks, where I got charged 40, but mine were 4 items, his was 2. Tom's going to have around $1k in that axle when it's done, 33 spline shafts, ARB, 4.88 gears, disc brakes.
Mark Wolfe
Lakeside, CA
Old September 18th, 2008, 12:06
mjma's Avatar
Yep, had to open up the inside of the rotor like you did, and the inside of the crown vic backing plate. Didn't have to open it too-too much...just did it with a dremel. I asked a machine shop to do it but they weren't sure how they'd do it with the backing plate being all odd shaped and such. I got a fresh new bit for the dremel and went to town, didn't take too long to open them up.
I think I may have taken a pic or two during the process, but don't have them anymore . But basically, mine looked like the above when I got it home from the junkyard, and when it was finished it looked shiny, but not as shiny as the above!! Here are the pics of the install. This was two years ago and this one went under my 96XJ, which at the time was on 31" ATs. It's currently on 32" MTs....and may be getting sold. I also installed an aussie at the same time, which I highly recommend!
And here is my other XJ 44 with 4.88s, a detroit, and still with drums!!
I've been thinking of switching the discs over to this XJ. The drums stop the 36s just fine. The only annoyance is that every time I go through some mud the brakes don't stop squeeking!!! I may convert this one over to discs also just to get rid of the squeeking!! I did the disc swap on the smaller XJ because when I pulled the axle from the junk yard one of the drums was kinda messed up.
Ford Explorer 8.8 Axle Disc Brakes $250 bigbadwolf54 MWC For Sale/Wanted Forum 15 March 4th, 2010 16:17
Explorer rear disc break conversion rEGAL2800@AOL.COM Modified Tech Discussion 12 September 17th, 2006 09:36
Teraflex (Ford Explorer) Rear Disc Brake Conversion Backspacing Thayer Modified Tech Discussion 21 August 6th, 2005 09:27
Ford 9 disc brake conversion thundermoose Modified Tech Discussion 14 February 19th, 2004 16:50
Colo: 2001 Ford 8.8" w/ disc brakes (Explorer) * $$400 sw99 For Sale: Private Party Only. XJ ITEMS ONLY 3 November 15th, 2003 05:29
