jeeptec
- atascadero california
I did the 4.7 power steering pump upgrade. I drilled out the pressure fitting like I've read. I only drill to 15/64 that is the same I.D as the line. I added a cooler. The cooler is mounted low. The pump whines about 1800 rpm. Anyone else have this issue? Yes it is a junk yard pump.
