Cheap crap. The crossmember mounting bolts didn't line up with the crossmember so I drilled out the crossmember holes a tiny bit to fit them in without screwing up the threads. Also the top of the mount does not have a hole to allow the dimple on the exhaust hanger plate to fit into and sit flush against. So I drilled out the exhaust hanger dimple.
Worked great for a while, now I'm noticing driveline movement again, along with a banging on startup and shutdown.
So i'd advise against them overall and will be replacing with an OEM mount soon.
I'm having a hard time finding one online that I need. All of them have 2 mounting holes and two studs? I need the one with 4 mounting holes and 4 studs I think.
