Old July 19th, 2007, 17:00
scott_m_c scott_m_c is offline
Question Help rebuilding RE trackbar joint
My RE HD trackbar is too short.
I just installed the RE5.5 lift kit, and when the axle is centered the TB joint is screwed on by only 4 turns. So, I got the longer coupler as discussed here...
http://www.naxja.org/forum/showthrea...t=1660+threads
I got the coupler without the joint... I am going to swap the joint over from the short coupler.
I am trying to find out how much torque is required for the threaded insert before putting in the set screw. I've emailed RE 3 times now with no response.
Thanks for any help.
Old July 20th, 2007, 16:26
F9K9's Avatar
F9K9 F9K9 is offline
Semper Fi
Re: Help rebuilding RE trackbar joint
Originally Posted by scott_m_c
I've emailed RE 3 times now with no response..........Thanks for any help.
Give them a call, they are very helpful!
Old July 20th, 2007, 16:36
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I used to go as tight as I could with hand tools, and had problems with the joints loosening up.
I talked to a few locals that use a lot of SF joints, and now I put the impact on them, probably 165 foot pounds. I've stopped having problems.
Old July 21st, 2007, 00:22
How can the joint get loose? The set screw keeps the threaded insert from turning. I'm sure after time the races will wear down but, 165 seems a bit much for a new joint. I'm not sure the threads on the insert will handle that, or the little nubs on the tool for that matter.
You really hit them with 165 from an impact?
http://www.rubiconexpress.com/Produc...C0362 2835520
Old July 21st, 2007, 00:33
BlueCuda's Avatar
BlueCuda BlueCuda is offline
First time I did this I hit them with an impact, it was a 3/8 impact and it shredded the tool for the joints LOL. I would NOT recomend that.
Old July 21st, 2007, 00:39
OK...
So, after you did that how tight did you torque it by hand?
I swear I've seen this discussed before, but I can't find it.
Old July 21st, 2007, 01:23
cal's Avatar
cal cal is offline
The bushings compress when they are new, and compress a lot more under stress. I have to replace them on my trackbar and UCA's about once a year, the 2.5" SF joint bushings on my lowers seem to hold up pretty good.
And yes, I really hit them at about 165 with an impact. I use my electric impact, it is "supposed" to push 200 foot pounds, but seems to nail things down at about 165.
Old July 21st, 2007, 11:00
BlueCuda's Avatar
I ghetto'd it with a punch to tighten it. Worked well, took it down for a re-adjust about 6 months later. Its been 2 or so years now and its all good.
T&T Customs Trackbar Bracket and JKS Trackbar ?'s 98XJDMB Modified Tech Discussion 8 March 13th, 2007 01:34
rebuilding fds d/c joint... mikeny59 OEM Tech Discussion 5 December 21st, 2005 16:02
HF Ball joint / U-joint tool half off deal... Ivan Non-Tech / Off Topic 7 May 25th, 2005 17:08
Rebuilding RE Superflex Joint. Question though JKTXJ Modified Tech Discussion 7 September 29th, 2004 07:42
Ball joint / axle - u joint replacement rail351 OEM Tech Discussion 7 September 21st, 2003 15:50
