Old May 14th, 2015, 12:46
ehall's Avatar
ehall ehall is offline
slop in the front driveshaft slip joint
One of my driveshafts has some slop in the slip joint, like in this video (not mine). It feels alright when its full of grease but eventually the grease gets worked out and then it starts to vibrate. I'm wondering if it help anything to replace the slip-yoke end of that or if the wear is on the male splines. Maybe just replace the cap? Any experience?
my '91 beater rebuild
Old May 14th, 2015, 13:00
md21722 md21722 is offline
Re: slop in the front driveshaft slip joint
i showed my local driveshaft shop one like that and they said, run it, get another, or we can make one for you. like you i greased it up and as long as the grease is there its good. been good for several thousand miles. i think it depends on how often you want to do a full grease.
Length of front DS slip joint? veedubshafer Modified Tech Discussion 4 June 19th, 2009 05:04
Front DS Slip-Joint Sleeve BADaXJ OEM Tech Discussion 3 November 24th, 2008 06:14
driveshaft slip joint,rebuildable? outlander OEM Tech Discussion 1 March 2nd, 2007 06:14
CV joint/u-joint question (front driveshaft) little red cheroke Modified Tech Discussion 9 February 19th, 2007 13:04
What grease to use on slip joint on driveshaft? Talyn Modified Tech Discussion 21 October 2nd, 2004 17:17
