Old April 20th, 2011, 15:54
kaden. kaden. is offline
speedo gear leaking?
just installed a SYE on my jeep, and i put the speedo gear in it feels/looks like it is in there but it seems to be leaking out of their while im driving pretty good? is it in there wrong? and yes the little O ring is in there. any ideas, could i just put a little silicone around it and stick it back in?
Old April 20th, 2011, 15:58
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Re: speedo gear leaking?
Fluid too high? Not seating all the way?
Old April 20th, 2011, 16:04
not sure how much fluid goes in their i just filled it up to the hole? seems to be seated in there it sits flat anyways?
Old April 20th, 2011, 16:56
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
i have to ask, but you filled it in the fill hole and not the hole where the speedo gear goes correct?
and when i rebuilt my t-case, i used some silicone on the speedo gear hole. doesnt leak and i dont see how it would be a problem
Old April 20th, 2011, 17:50
haha yeah to the fill hole not the speedo hole. (thats a lot of fluid). well ill try some silicone on the speedo hole hope that works headed to moab tommorow
Old April 20th, 2011, 19:12
aintright aintright is offline
how tight did you tighten the little bolt. i've had that problem and just put another turn or two on the bolt and it stopped
Old April 20th, 2011, 22:18
EricsXJ's Avatar
EricsXJ EricsXJ is offline
NAXJA Member #616
Was the o-ring new or used?
I've had that experience before and I believe that the used o-ring was stretched out just slightly enough for it not to seat properly or produce a good enough seal. Put in a new o-ring and fixed it.
www.ericsxj.com
Old April 21st, 2011, 07:12
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
2x on the O-ring theory. There's a sharp edge where the O-ring slips over to seat in place. Most likely you tore the O-ring when you installed the speedo gear housing....
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old April 21st, 2011, 07:15
dgrigorenko's Avatar
dgrigorenko dgrigorenko is offline
Agree on the old oring, I have Had all my fluid leak out from one that was slightly pinched... I always get a new one now. I think of it as cheap insurance
Sent from my Liberty using Tapatalk
leaking PSC steerin gear box, wtf??? knucklehead 61 Modified Tech Discussion 11 August 29th, 2010 23:27
Speedo Gear/ pinon speedo drive?!!! selarep Modified Tech Discussion 13 September 15th, 2006 01:18
Leaking gear lube..... Powderhound Modified Tech Discussion 2 April 11th, 2005 19:54
I need help, which speedo gear. tcharon SoCal Chapter 2 January 27th, 2005 20:19
speedo gear steelheader Modified Tech Discussion 1 May 5th, 2004 19:40
