Prev Previous Post   Next Post Next
Old January 10th, 2019, 16:44
MickeyS MickeyS is online now
Speedo gear leaking
231 case is leaking from the bottom of the speedo gear housing. did some searches and it seems people have this issue. some say there are two o rings. Where exactly do the two o rings go? there is one recessed in the housing that i see, and i see on multiple youtube videos, but i don't see two.
anyway, I replaced that oring and reinstalled. It's still leaking. what am i doing wrong? if i were to add RTV, where exactly should I seal?
speedo gear sleeve and gear torn up sartor Modified Tech Discussion 8 August 2nd, 2018 16:52
Leaking speedo gear after SYE install-fluid level OK-did I simply overfill? husker25 Modified Tech Discussion 12 June 24th, 2012 10:41
speedo gear leaking? kaden. Modified Tech Discussion 8 April 21st, 2011 08:15
leaking PSC steerin gear box, wtf??? knucklehead 61 Modified Tech Discussion 11 August 30th, 2010 00:27
Speedo Gear/ pinon speedo drive?!!! selarep Modified Tech Discussion 13 September 15th, 2006 02:18
