Prev Previous Post   Next Post Next
Old January 8th, 2019, 09:39
denverd1's Avatar
denverd1 denverd1 is offline
rebuilding front DS slip joint
think I found the source of my vibes. Front slip joint is beat down pretty bad. never seen any info on rebuilding these, have already done centering ball and the other joints are fairly new. Is this shaft toast?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
slop in the front driveshaft slip joint ehall OEM Tech Discussion 1 May 14th, 2015 13:00
Length of front DS slip joint? veedubshafer Modified Tech Discussion 4 June 19th, 2009 05:04
Front DS Slip-Joint Sleeve BADaXJ OEM Tech Discussion 3 November 24th, 2008 06:14
Help rebuilding RE trackbar joint scott_m_c Modified Tech Discussion 7 July 21st, 2007 10:00
rebuilding fds d/c joint... mikeny59 OEM Tech Discussion 5 December 21st, 2005 15:02
