94xjkyle
- north-cali
ok, i have the RE 4.5" lift and it has the track bar that mounts to the factory mount, after you drill out the hole with a 5/8" drill, and now that i have done that, when i turn it makes a large clunking noise, and the track bar moves when it clunks, i have checked the tourque on all the bolts/nuts on everything, and it is making that noise and it cant be good. has anyone else had this problem, and if so how did you fix it?
