Old February 9th, 2018, 08:18
burntkat burntkat is offline
NAXJA Member #1145
Electric air pump info needed
Gents (and the occasional lady)-
I am looking for an electric air pump for my son's 97 XJ. He's not running anything crazy like air suspension or air tools, but I'd like to have something that gives at least an option for future hardmount and use to fill a 5 gallon air tank to 100PSI or better for future expansion.
Not looking to run air lockers, so need not be a $300 ARB.
I have done some searching on the web, but the sources don't seem current- one article on fourwheeler.com was written in 2001.
Anyone got some recommendations?
EDIT to clarify- Slime and similar units need not apply, unless they truly are awesome. I've never been impressed with anything of the sort that comes in a plastic caase or includes an integrated basketball filler, light, etc...
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old February 9th, 2018, 08:23
NAXJA Member #1145
Re: Electric air pump info needed
... and, I may have answered my own question here-
Think this is the one we used to modify back in the early 00's by removing the head nd tapping it to use a proper air chuck:
https://www.amazon.com/Industries-MV.../dp/B000BM8RT8
Anyone got input on this unit, or better recommendations?
Old February 9th, 2018, 17:11
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
CO2 tank is the simplest way. One of the better investments.
Or throw in a York if you want a OBA system.
Viar is also another option.
Old February 9th, 2018, 17:19
trippled trippled is offline
I have a viair 88p. Works well. I went between that and the mv50. The 88p seemed to have a little better fill times. It does get pretty hot like they say, and the gauge doesn't read right but not too worried about that.
Old February 9th, 2018, 19:27
DutchVDub's Avatar
DutchVDub DutchVDub is offline
I used to use one of those red compressors from Amazon, not the fastest but it always worked. I have a VIAIR setup in my current XJ and am really happy with it. I'm personally not a fan of the CO2 setups. The tanks take up more room than just a decent compressor and you have a limited amount of air. The compressor might be a bit slower, but it'll fill up a nearly unlimited amount of tires. I used to have an ARB CKMA12 compressor and that thing was impressive. I used it to reset the bead on my 39's, it was a great little compressor. The only reason I don't still have it is because I left it in the Jeep when I sold it.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 9th, 2018, 23:53
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
An MV50 has been in the back of the XJ for over ten years, as a backup to the CO2 tank.
https://www.flickr.com/photos/lwade/...7602104743143/
The air outlet has been tapped for a standard air chuck, so the same hose, used for the CO2, also works with the MV50.
It's an OK compressor but it's not big enough if you seriously air down a lot. That's that the CO2 tank is for.
I recommend for getting a CO2 tank, besides airing tires, it can be used for all sorts of air tools and impacts.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old February 10th, 2018, 02:45
NAXJA Member #1145
"Electric air pump". It's right there in the subject.....
Old February 10th, 2018, 03:01
NAXJA Member #1145
Looks like things haven't changed, then. I am running the same compressor in my other rigs. I see the Viar 88p is well-regarded and actually a few bucks cheaper. I think I'll hand off my nodded MV50 to him, perhaps hard mount it in the engine bay (having removed the air box for this purpose) and upgrade myself to the Viar 88p. For roughly the same price, and not having to work on it to make it suit, it's a no-brainer.
(EDIT to add - although, looking at it more closely, the Viair has the integrated LED, and a built-in air hose. Neither of which I want/need, and the hose could work against my needs in terms of mods. Think I am right back to the MV50, as it's a proven commodity by myself and folks that use theirs harder than I do.)
I have CO2 in my 90 XJ and my 89 S10. I don't want to go that route for his vehicle just yet, due to apace constraints. He's a musician and looking into learning to weld as a profession, so will need as much cargo room as he can manage.
Old February 10th, 2018, 06:56
smokeyyank's Avatar
XJholic
So are suggestions....
Old February 10th, 2018, 13:15
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Having gone from a viair to a York, York 210 OBA is hands down the best compressor, albeit not electric. I run one with a 7 gallon tank and it is awesome. I can fill up a 35 from 10-25 psi in about 45 seconds
Old February 10th, 2018, 14:16
NAXJA Member #1145
I'm sure it is awesome. Is it electric? No? Well then why are we mentioning it?
Old February 10th, 2018, 14:34
DutchVDub's Avatar
My VIAIAR OBA is the constant duty kit recommended for up to 37” tires. It comes with a 450C model compressor. I think the ARB CMKA12 filled my tires faster, and obviously took up less room. I think if I were doing it again I’d go with the little ARB compressor.
Old February 10th, 2018, 19:29
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Looks just like the masterflow tsunami I picked up at pepboys awhile back. May not be the best but it does what I need. Don't know if it will hit the 100psi mark but it works well
Old February 10th, 2018, 22:53
1990JEEPXJ's Avatar
Sorry for mentioning something I thought was worth mentioning based on my experience with both. I will no longer try and be helpful as it seems you are not open to suggestions and already made up your mind in your first post and just want that decision confirmed.
I mean, my suggestion only meets all of the demands based on 100psi, 5gal tank, and future expansion of the system.
But proceed being sarcastic in your responses.
Oh, if itís electric compressor suggestions or GTFO, then spend the money and get a proven name such as Viair and be done.
Old February 11th, 2018, 07:47
NAXJA Member #1145
I mean, my suggestion only meets all of the demands based on 100psi, 5gal tank, and future expansion of the system. .
Actually, no your suggestion didn't fit the bill. The very first qualifier was 'electric'. Further, I noted that I am not building an extreme rig here. Engine powered OBA is much closer to that than what I asked about.
Sorry you have issues with reading comprehension.
Any info on keeping my Electric Fan on for 15 min after shutdown? Redsnake Modified Tech Discussion 10 May 4th, 2012 08:09
12v electric WINCH INFO only in a Jeep Midwest Chapter 16 July 15th, 2011 11:08
97 XJ fuse diagrams and info about electric fan indianajeeper OEM Tech Discussion 7 April 13th, 2011 14:36
Electric water pump? jdxj Modified Tech Discussion 11 July 27th, 2009 21:31
Electric Water Pump? Root Moose Jeep Street and Performance 7 September 4th, 2008 16:13
