Old February 11th, 2018, 18:50
Boot13's Avatar
Boot13 Boot13 is offline
NAXJA Supporting Vendor
Re: Boot13's Build Thread
Originally Posted by DutchVDub View Post
https://eastcoastgearsupply.com/i-15...ring-tool.html
You can rent it for $250, but still might be cheaper to find a shop to do it.
I'd probably go the hole saw route I read about on the forum. Unless that tool makes it that much easier to justify the cost.
-Boot13
1995 XJ
HobbyKeep Custom 3d Printing
Old February 12th, 2018, 12:17
Boot13's Avatar
Well the shop said the 30 spline carrier had not shipped yet and they had a 35 spline arb locker sitting on the shelf collecting dust. They gave me a great deal on it so I guess now I am going to boring those spindles out. Gah I'm so weak willed, so much peer pressure.
-Boot13
1995 XJ
Old February 12th, 2018, 13:05
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Even though it’s overkill for the tires you’re running, it’ll be way better in the long run.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 12th, 2018, 20:33
trippled trippled is offline
I have one if those 60s and that's exactly what I intended to do. It actually seemed relatively easy just time consuming. The hole saw parts were easy to get.
Then I got a 14 bolt. If I ever go tons.
Old February 14th, 2018, 12:05
akendal4's Avatar
akendal4 akendal4 is offline
I find it odd that you broke a shaft on the road. When I had that axle, I was on 37s and drove it frequently on the road with no problems. Also, I highly suggest you measure the spindles to ensure there is enough material for boring them. Because that came out of a 73 Dodge W300, it may not have large enough spindles. I never measured them when I had it since I already had another 60 to go in its place.
Old February 14th, 2018, 13:05
Boot13's Avatar
I was surprised it broke too. I think it was just turning a little too sharp out of the stop sign it was less than a 90 deg turn, so pretty sharp I should of known better. I had put plenty of miles on it too and it had been great, just a little chirpy while parking.
The spindles are already around 1.5" ID (quick tape measure measurement I took to figure out PVC pipe size for magnet) and from what I have gathered they need to be 1.56" ID to hold the 35 spline. So that basically 1/32" of material needs to be removed from all around the inside.
I do need to get a precise measurement and I will be doing that this weekend. I may not need to bore it all. Fingers crossed.
-Boot13
1995 XJ
Old February 14th, 2018, 13:14
akendal4's Avatar
Good stuff. Just wanted to chime in and make sure it was all checked before you spent a bunch of money on something that might now work
Old February 14th, 2018, 13:20
Boot13's Avatar
Yep and its greatly appreciated. Thanks for looking out.
-Boot13
1995 XJ
Old February 15th, 2018, 21:43
Boot13's Avatar
Well it was nice out and I got a chance to get a better measurement ID was 1.45" and they are in fact too small to bore out. The limiting factor is that little notch that the spindle washer uses.
I'll just keep it 30 spline as originally intended.
-Boot13
1995 XJ
Old February 16th, 2018, 06:37
DutchVDub's Avatar
That sucks. Hopefully the limited slip keeps things happy. Also, hopefully it was just a fatigued shaft in the first place.
...sorry...another build thread... blondejoncherokee Sierra Chapter 1501 June 30th, 2015 15:07
my 91 xj build thread Vanimal Modified Tech Discussion 68 March 25th, 2012 18:22
